Results 1 to 10 of 15
Thread: Help pls!! Is there an....
    Regular Member ACE.TAG's Avatar
    Feb 2007
    hamilton
    Default Help pls!! Is there an....
    easy way of removing the front indicator bulbs from a facelift veccy as i want to change the orange bulbs for the silvatec ones??
    It looks like you need to remove the headlight but surely not!!!!
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Feb 2007
    hamilton
    F**king hell what a job just to remove an indicator bulb!! Cheers for that mate!!
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Tell me about it!!
    Regular Member Darrell's Avatar
    Feb 2007
    Wolverhampton
    sore subject, fell out with mine when i had car
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    noooo there`s no need to remove the bumper and headlamp,you can get
    at the indicator bulb holder on the drivers side by removing the top half of
    the air box and if you look up closely right behind were the indicator is you
    will see aand feel kind of a lollypop stick and if you turn it then pull and
    wiggle it a bit at same time it`ll come out and on the passenger side just
    lift the battery lid up and feel around for the kinda lolllypop stick and repeat
    the same as the drivers side,refit ya replacement bulbs and replace the
    holder,easy peasy when ya know how.
    Feb 2007
    hamilton
    Cheers bud i'll give that a try!!! as you said easy when you know the trick to it!!
    Feb 2007
    hamilton
    You don't happen to know if the pins on the front indicator bulbs are offset or even as the rear ones are offset??
    Feb 2007
    hamilton
    I've now got out the one on the drivers side but i can't get the the passenger side one out it will turn but is there anything obstructing it do you know???
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Quote Originally Posted by Andyvec View Post
    Nice bit of advice there chap!!
