Results 1 to 10 of 14
Thread: no gears
    New Member lee1980s's Avatar
    Mar 2018
    redditch
    Vehicle : 1.9 cdti
    Trim : elite
    Engine : diesel
    Default no gears
    hi people need some help . I've got a 1.9 cdti 150 . just changed engine and also put new duel mass on at same time . I've bled the clutch but still no gears . helpppp
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    When you say "no gears", what exactly do you mean?
    Do you mean the clutch isn't working and won't let you engage gears when you push the pedal down? (with engine running)
    Or do you mean that you can engage the gears ok, but there's no drive when you let the pedal back up?
    With the engine off, can you select it in/out of gears ok?
    Mar 2018
    redditch
    Vehicle : 1.9 cdti
    Trim : elite
    Engine : diesel
    Yea when engine running it won't engage . I've bled the brakes and there's no air in there . I've had the engine out 3 times now it's driving me mad
    Mar 2018
    redditch
    Vehicle : 1.9 cdti
    Trim : elite
    Engine : diesel
    and yes when the engine is off it will go into gear no problem . I'm thinking maybe thrust bearing maybe
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Surely you mean you bled the clutch CSC (concentric slave cylinder)?
    Any chance you might have put the friction plate in backwards?
    https://www.vectra-c.com/forum/showt...-plate-help!!!
    Mar 2018
    redditch
    Vehicle : 1.9 cdti
    Trim : elite
    Engine : diesel
    Yea bled the clutch . no was defiantly in the correct way . really scratching my head as to what it is
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    If your 100% positive the clutch is bled properly, and everything was assembled the correct way round, then I’m about stumped too fella.
    Was it it a complete new flywheel & clutch assembly you fitted? The flywheel and clutch are definitely compatible?
    Mar 2018
    redditch
    Vehicle : 1.9 cdti
    Trim : elite
    Engine : diesel
    Yea got from neo brothers . everything is new it's baffled about 6 mechanics so far
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Removed the wee blanking cap from the end of the slave cylinder connection/pipe before installing it?
    When I had a new clutch fitted to my Insignia, there was a big warning on the packaging to say to make sure and remove it before fitting.
    (clutching at straws now....... )
    Mar 2018
    redditch
    Vehicle : 1.9 cdti
    Trim : elite
    Engine : diesel
    I wish it was that . I'm clutching at straws aswell it's really doing my nut in
  1. no gears...........please help
    By bigdan1505 in forum Engine & Drivetrain
    Last Post: 3rd April 2013, 18:54
  2. Not enough gears!
    By Flaninacupboard in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 08:48
  3. gears
    By howey in forum Engine & Drivetrain
    Last Post: 27th May 2008, 19:54
  4. how many gears in the 1.8 vvt?
    By jaff in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 19:09
  5. no gears - help!
    By Digital_kid in forum Engine & Drivetrain
    Last Post: 23rd May 2007, 13:53
