Likes Likes:  1
Thread: cdti temp gauge trouble
    DURHAM
    Default cdti temp gauge trouble
    150 cdti .
    Genuine stat fitted approx 18 months ago ,since then no coolant trouble .
    Last week after a 10 mile drive I noticed the temp gauge creeping up and cold heaters ,but when reaching 3/4 the needle drops to normal position and heat returns.
    Today , a 5 mile trip ,10 mins engine off ,on trip home needle maxxed out and flashing coolant light .
    I was thinking thermostat but opcom shows nothing .
    Coolant slightly down ,topped up , let it idle for 10 mins with cap off and the needle sits at 90 ,after less than a mile driving needles up in the red and cold heaters .
    Head gasket or not ?
    DURHAM
    That should read idles at 95 .
    Just been back out ,took a couple of mins and the temp was up to 95 on idle then rising as I kept the revs up .
    Administrator plasma's Avatar
    On the Forum
    466 Post(s)
    Engine : 150
    Mileage : 74000
    Have you checked to see if the water is flowing back into the header tank? Maybe waterpump?
    maybe stat stuck shut?
    DURHAM
    Ran engine till needles at 90 ,no coolant coming back to tank and top rad hose is red hot ,suggesting the stat is open and working correctly .
    Dug some paperwork from previous owner ,June 2015 87000 miles INA cambelt kit and Circoli wp fitted . Car now has 120650 miles.
    I`m not impressed with Circoli stuff ,had wp leak on a Rover 45 and my dads old Vec XER had 2 stats fail very early .
    If it is the wp theres genuine for £35 and just change pump or do I risk this cheaper kit and pump from Neo ,https://www.ebay.co.uk/itm/Saab-9-3-...QAAOSwz-5ZfGs7
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I’d be thinking the water pump has died and allways fit genuine with these either from dealer with the club membership card or GPS as a lot of Neo stuff isn’t genuine.
    Youve been here since 07 so you’d have seen the agro people of had with none genuine parts on this engine myself included
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
    DURHAM
    Neo do a genuine belt kit and pump for £105 but its out of stock ,Saabtech https://www.ebay.co.uk/itm/142274230200
    Good point re non genuine , dads thermostat trouble a perfect example .
  7. Likes Dog_Book liked this post
  8. #7
    DURHAM
    If its the wp I think the cam belt will be changed along with blanking the swirl flaps .
    However ,I can only find these part numbers on the inlet -
    46823849
    3.65704.02
    Which manifold is this ,early or late ?
  9. #8
    DURHAM
    A lot of searching returns this ,http://vi.vipr.ebaydesc.com/ws/eBayI...10&category=33
    Looks like a 15mm blank kit is needed .
  10. #9
    DURHAM
    Well . it was indeed the water pump that had failed . I was very surprised to find it had seized ,I had thought the impeller was at fault .How the belt survived a couple of hundred miles of 3 mile trips I`ll never know , no burning smell or squealing .
    Genuine GM pump fitted .Decided to replace the belt kit with the same brand that survived pump seizure , INA .
  11. #10
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 13400
    Quote Originally Posted by 2MUCHGAIN View Post
    There's a guy, James from Leeds that will supply and fit a welded manifold for about £160.
    I personally wouldn't trust the glue in plugs.
    https://www.facebook.com/ajmotorsvauxhall/
    Alan
  1. vectra c cdti 120 no temp on temp gauge?
    By Tropax in forum Engine & Drivetrain
    Last Post: 25th March 2016, 22:55
  2. vectra speedo rev counter fuel gauge temp gauge stopped working
    By ianfagan in forum Vectra C / Signum Troubleshooting
    Last Post: 18th August 2013, 19:45
  3. Temp gauge on my 1.9 cdti (150)
    By winton40 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st April 2011, 14:19
  4. cdti 150 temp gauge sits at 70 most of the time?
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2011, 13:19
  5. temp gauge issue on 1.9 cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2009, 14:54
