Thanks Thanks:  6
Likes Likes:  19
Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Dipped Lights Distance - not brightness
  1. #41
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    my bad I thought the preface was like my 57 plate Astra TT and just reflector .
    ok can some one post up some pictures regardless of year .
  2. #42
    May 2009
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Quote Originally Posted by fatfred View Post
    I wonder if that will allow enough cooling air into the fan? I hope it does because it should then be an easier mod...hids out leds in.
    I'm sure they do a slightly less powerful bulb with a heatsink instead of a fan. I think it is about the same size though so you would still have the same problem with getting the caps to fit.
  3. #43
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    as others have said, HiD's will be illegal soon unless you do meet rigid new rules. I had exactly the same problem, did Duncan's fix (already mentioned
    https://vectra-c.com/forum/showthrea...ghlight=lights
    then fitted better bulbs, I went with Halfords 100%+ purely because they were on offer, and had no more problems on unlit twisty A or B roads, I suggest you at least try the fix first, it'll cost you noting but a little time.
  4. #44
    Mar 2010
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Quasar View Post
    hello all,
    ok just fitted a pair of osram nightbreakers today, and went for a drive in the dark to my parents, which was dual-carriage way and some country roads,
    whilst the short view is clearer, i would say there wasnt really that might different to the previous bulbs which were standard ones,
    they are in the correct way round
    they are fitted firm and flush
    the lens's are clean
    the bulb lens in the frame is opaque , but i think its meant to be like that ( can they be removed )
    so what do you think ?
    As i read so many reports that the difference is so vast, from normal bulbs, at the moment i am not impressed., something must be not right.
    the way i fitted them was removed bumper and undone the 3 screws and slotted headlamp unit out, as it was so much easier, and gave em a good clean from flies n leaves trapped.
    I did not open the unit up apart from the rubber boot, to take bulb out.
    so what ya think could be wrong ?
    very little will give you a big improvement unless you do the fix first, as the beam will still be too low. You could put 150w bulbs in, if the beams are set too low you still won't get distance.
  5. Thanks Quasar thanked for this post
  6. #45
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by Grumpy1954 View Post
    Ey-up Grumpy..how many times do you have to suggest it before anybody takes notice? Ah well.....!! We tried....
  7. Likes Grumpy1954 liked this post
  8. #46
    Feb 2018
    England
    Vehicle : Vectra C 1.8 LS Petrol
    Trim : LS
    Engine : 1.8
    Year : 2003
    altered beams - there is a bit better distance, but i wouldnt say WOW what a difference for brightness,
    my peugeot 206 had an awesome range with standard tesco bulbs !!!!
    Will do for now, until i get some of those LED lights with fans, and see how they fare
  1. Vectra VXR/OPC stopping distance
    By brasch in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2013, 13:21
  2. vectra is going the distance
    By nicj in forum The 'Off Topic' room
    Last Post: 5th August 2012, 17:47
  3. distance to meets
    By daddyjay in forum South West - RO (vacant) / ARO - (dave234)
    Last Post: 27th November 2011, 23:26
  4. Side lights off with dipped beam ?
    By opel_estate in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 19:45
  5. Dipped Lights/ Lower Beam
    By jatint in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 18:58
