Thanks Thanks:  6
Likes Likes:  19
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Dipped Lights Distance - not brightness
    Feb 2018
    England
    Vehicle : Insignia SRI CDTI
    Trim : SRI
    Engine : 2.0
    Year : 2011
    Default Dipped Lights Distance - not brightness
    Hello All,
    The main beam is nice and bright not an issue,
    Its the normal dipped mains, they dont give much distance, probably two long white lines worth,
    When i had my Pug 206 - and normal 55w bulbs - i could see ahead at least 3.5 long white lines worth,
    How can i increase the "view" distance of the lights -
    Yes i have tried the light beam adjuster - this makes no diff - only a few mm here n there
    Do u get new bulbs - and what is recommended,
    ( i cant afford hids, or expensive bulbs )
    Thanks in Advance
    Regular Member any-mgzt's Avatar
    cheshire
    9 Post(s)
    Trim : basic
    Engine : Z19DT
    HID's are MOT fail from May 20th
    Sent from my SM-N910F using Tapatalk
    South Central - Assistant RO Matty2Fatty's Avatar
    Mar 2014
    West London
    87 Post(s)
    Trim : Elite Estate
    Engine : 1.9 CDTi 16v 120 BHP
    I would probably get the lights checked at an MOT station to make sure they are adjusted correctly, I thought mine weren't lighting up as far as I'd like them to be, so took it to my MOT tester and he looked and found they were pointing low "but only just, still would have passed" but it did make a difference that I could see much further afterwards.
    Also make sure the lenses are clean, sounds stupid I know, but with this naff weather and all the salt and grit on the road, they get dirty quickly, again mine last night I was thinking they weren't lighting up very much, a good clean later, was fine again. True, by the time I reached the end of the road they were filthy again, but nevermind.
    Click HERE to see up and coming events
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by Quasar View Post
    Hello All,
    Thanks in Advance
    Hi,
    Try Duncans method.." A kind of fix for the poor pre facelifts headlights" from his post dated 7/11/2007 - I used it to improve distance our 55 Reg Facelift Hatchback..along with Ring automotive "Xenon" Ultimate (or Maximum) replacement dipped beam bulbs. Cheers!!
    Feb 2018
    England
    Trim : SRI
    Engine : 2.0
    Year : 2011
    MOT passed 3 weeks ago fella
    no idea what bulbs are in the car- he nightbreaker and phillips bulbs seem a decent price and wont break the bank, maybe ill try those.
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    HIDS are around £ 30 a pair, take about an hour to fit. Yep they'll fail the mot but at least you will be able to see your way to the MOT station. Best money i spent on mine except perhaps the 314s or the@Teapot remap.
    Feb 2016
    Pontypool
    Trim : Exclusive
    Engine : 1.9 cdti 16v z19dth
  8. Thanks Quasar thanked for this post
  9. #8
    Regular Member RBH's Avatar
    Jan 2008
    Central Scotland
    109 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
    Quote Originally Posted by necrophobic75 View Post
    I can endorse this actual kit and seller.
    Bought this kit for my daughters car......can't fault it or the seller in anyway.
    only £15 delivered.
  10. Thanks Quasar thanked for this post
    Likes necrophobic75 liked this post
  11. #9
    Feb 2018
    England
    Trim : SRI
    Engine : 2.0
    Year : 2011
    looks like a lot of work with all those wires - id prob mess something up.
    mind you its staying brighter later now, as its spring.
  12. #10
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Have you seen others solutions in the modifiying section yet?
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  1. Vectra VXR/OPC stopping distance
    By brasch in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2013, 13:21
  2. vectra is going the distance
    By nicj in forum The 'Off Topic' room
    Last Post: 5th August 2012, 17:47
  3. distance to meets
    By daddyjay in forum South West - RO (vacant) / ARO - (dave234)
    Last Post: 27th November 2011, 23:26
  4. Side lights off with dipped beam ?
    By opel_estate in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 19:45
  5. Dipped Lights/ Lower Beam
    By jatint in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 18:58
