12th April 2019, 10:34
#41
Originally Posted by
pek1
Another question, I thought I should try to adjust the gear linkage this weekend bu,t since all gears do engage fine with engine off I guess this isn't needed? Should mean that alignment is OK?
Whilst we're on the subject of gear changes, I noted that the volume of oil you said you filled the F40 with is a little too much. You need to put in 2.2 litres, which when added to the 0.2 litres that stays in the casing, makes 2.4 litres in total, rather than putting in 2.5-2.6 litres which will make up to 2.8 litres in total. The more oil you have above 2.4 litres the rougher the gearchange will be.
pek1 liked this post
12th April 2019, 11:29
#42
LastOne
Yes, correct, I've been thinking of draining some of the oil but since this feels more like a mechanical problem (getting into gear) and not only notchiness I'm not sure it would help. My other car got the same amount and doesn't behave like this. Both are of course still a bit notchy so I'll put this on my to-do list.
12th April 2019, 11:37
#43
Just reset the cables then it’s easy
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
12th April 2019, 11:50
#44
Dog_Book
Will try, backed off the last time since the cable locks looked like someone used a crowbar or something on them.
12th April 2019, 11:55
#45
Just go to Dog_Book's diary - doing that solves all problems in the known universe.
12th April 2019, 12:13
#46
LastOne
Or ST200’s, there’s a how2 for this I’m sure?
12th April 2019, 12:15
#47
LastOne
Right, apart from getting depressed seeing all that's being done to that car knowing the state of my cars
12th April 2019, 12:17
#48
Dog_Book
Also depressing but you're right, I have the how2 and read his instruction too.
12th April 2019, 12:22
#49
Always go for the cheapest option first mate and yes use the how2 it'll guide you through it easily
12th April 2019, 21:02
#50
Cables have been reset now and you were right, easy job. Haven't driven much since but gear changes feel more "crisp", car still pulls forward a bit when trying to get into 1st gear with clutch engaged though. I'll drain some oil when servicing but guess I have a clutch problem
northpole
