Thread: Tyre pressures quick question ?
    Regular Member raymie.d's Avatar
    Feb 2007
    Glasgow
    Default Tyre pressures quick question ?
    I have changed the wheels and tyres on my car with the result of strange, almost wobbly handling when turning. The wheel and tyre sizes are the same the only difference is the load rating. The previous tyres were 91 rated, the new ones are 95 extra load rated. I have a 1.9 CDTi.
    The question is: Does the higher load rated tyre need a higher pressure?
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by raymie.d View Post
    No same pressures, but as you've changed the wheels have you had them balanced? Are they identical wheels with the same dimensions? or slightly different? Was something knocked while being changed to throw the geometry out. Was it a Vx side jack, trolley jack or car lift. Oh so many parameters to consider.
    Dec 2005
    In the sponge-monkey tent
    Have you checked the bolts are torqued up properly...last thing you want is a wheel falling off
    Edit: Have you done many miles on them yet? New tyres on the front will often understeer, especially if the rears have not been changed.
    Also are they aftermarket, if so you may need spigot rings ??
    Feb 2007
    Glasgow
    They are the correct fitment, have spigot rings and are perfectly balanced. Thet just dont feel direct when changing direction, as if the tyre is underinflated and moving laterally when turning. I have seen a few sites that say you should be 4.5 psi higher for a higher rated tyre, I was wondering if anyone knew for definate, also in the owners manual for the 3.2 which uses this rating of tyre it is quoted at 40 psi.
    I have the black DTM alloys off of the "Vectaru" on my car and they are 18" with 225/40/18 toyo's t1r with a load rating of 92y and i run them at 40 psi all round i did do a bit of experimenting with pressures when i first fitted them and the higher pressure is just about spot on in all weather conditions HTH
    Regular Member cameraman's Avatar
    Leicester
    I had 2 new tyres from Dick Fit, noticed wheel wobble at 70mph on the way home & the steering seemed off centre, when I checked it at the local filling station I had 24psi on one side & 35 on the other, whats more I have found marks on the rims now I've washed it & they kept me waiting 2 hours.
    Running 38psi all round on 225/45 18's
    Feb 2007
    Glasgow
    Thanks drinky. I went to the filling station and put them up to 40psi and it feels alot more sure footed.
    Regular Member Little John's Avatar
    North West
    Quote Originally Posted by cameraman View Post
    Take photos of the damage, National tyres scratched one of mine a few weeks ago when I got a puncture on the other side of the country. I took it to a local place and they are going to sort it out they believe it can be repaired but if it isn't done to my satisfaction they will be replacing the wheel. The guy said they would repair or replace depending on the damage so I just made it clear I wasnt happy with a repair as I have seen problems on repaired wheels but he wheel has been repaired in the past before I got it.
  1. Quick Tyre Question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 17:52
  2. Quick Tyre Question.....
    By Signum_CDTI in forum Handling & Braking
    Last Post: 23rd January 2008, 23:06
  3. Quick tyre question...
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2007, 17:22
  4. A quick tyre question please!
    By Adamdavi3s in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2007, 10:08
  5. Quick tyre question ...
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2006, 17:27
