Thanks Thanks:  2
Likes Likes:  4
Results 1 to 10 of 23
Thread: DPF Drill & ECU Remap - thoughts please.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default DPF Drill & ECU Remap - thoughts please.
    Guys,
    I keep getting the message on the dash every few weeks on the Astra J CDTI 2011 saying DPF full, continue driving.
    My thoughts are to sell the car and get a petrol, but we like the car and waited ages to find the right one. So I have been speaking to a local garage who did a DPF removal and Remap on my mates BMW X5.
    Basically, the guy at the garage said they wont remove it on the J, but they drill holes in the filter, and then re-map the ECU. All in £350.00.
    Whats your thoughts guys?
    Thanks,
    G
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    ask teapot see what can do for u
    North West - Assistant RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    80 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    bit pricey.
    because........SIGNUM!
    Mar 2017
    Northern Ireland
    Trim : SRi XP
    Engine : CDTi 150
    bear in mind the new MOT rules coming!
    Birmingham
    Quote Originally Posted by paula9568 View Post
    @Teapot...? Whats your thoughts mate?
    Birmingham
    11 Post(s)
    From what I've read, remaps on Astra-J's are hit and miss. The person doing it, REALLY needs to know what they're doing.
    Apr 2008
    West Yorkshire
    I'd get the ecu software updated at the main dealer as there was a technical service bulletin about the dpf regeneration procedure that the ecu does, then get the dpf manually/ forced regeneration and then drive it at high speed low gear to perform an active regeneration. You could see if you can get this update for free under warranty under the 'fit for purpose' route etc
    New mot rules and test will cause a failure if any visible smile is detected ie visually detect if someone has drilled through the dpf etc
    Birmingham
    Reference the MOT, apparently the way this is done is at the top, so technically when underneath the car it wont be visible .
    How can I check if there is a S/W update for this?
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    192 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Speak to Vauxhall?
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  11. Likes Big Dave liked this post
  1. Performance remap thoughts
    By HarrysDad in forum Petrol Engine related
    Last Post: 5th February 2015, 20:31
  2. D.A. KIT but need a drill
    By ghost00 in forum Detailing and Car Care Discussion
    Last Post: 1st September 2014, 21:20
  3. Regal 3.2 remap, thoughts.
    By Hyperhart in forum Petrol Engine related
    Last Post: 14th March 2011, 21:32
  4. Replies: 16
    Last Post: 13th October 2010, 16:19
  5. EDS Remap on 2.8 V6 Turbo. Your thoughts?
    By philw80 in forum Petrol Engine related
    Last Post: 28th May 2010, 17:11
