Was looking for my Qashqai and found this which might be helpful if you have the same problem with wiper linkages https://www.askthemechanic.co.uk/sho...repair-channel
I put a cable tie on mine 4 years ago. Bet it falls of tomorrow now
Yup!, had cable tie on mine for years & years, Sooooo long i even forgot id done it till i saw this thread.
yep me too, even had to show a mechanic the how2,you just can,t beat this forum
What does this fix?? My wipers are scatty on setting one they can randomly go at full speed then go back to super slow.
And also their noise. They smash into the bonnet and into the pillar bit every time as if the motor is going too far both up and down.
Not sure if this trick can fix this or if my issues are just the actual motor
Sent from my ONEPLUS A5000 using Tapatalk
Yours sounds like its the motor had the same problem on my signum. The fix is for the linkage if it pops apart but like others have done the cable tie is a cheap fix but i stumbled across it and thought it might have been useful as another way to fix the linkage problem
if fix my linkage using this https://youtu.be/viAyWL4HZH4
