Thanks Thanks:  2
Likes Likes:  3
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: No noise/sound from indicators?? & Spanner light
  1. #11
    Oxfordshire
    11 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by michale_kid View Post
    Now the door bleep has been brought to my attention who knows what else.
    Just remembered something else that should make a bleep. Putting on the left or right parking light by flicking the indicator stalk left or right with the key removed.
  2. #12
    Regular Member michale_kid's Avatar
    Feb 2015
    Just tried that, no beep even with door open. unsure weather other things beep but i tried no seatbelt, door open when driving none of these things make a sound they just signal on the dash.
    Sent from my ONEPLUS A5000 using Tapatalk
  3. #13
    Oxfordshire
    11 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    IIRC, the sounder for lights, indicators, and other warning noises is in the CIM unit. Whether it's a loose connection or CIM problem though is anyone's guess.
  4. #14
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    129 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Mileage : 201000
    As has been said previously the fault lies with the Cim ,
    There is a piezo speaker on the back of the circuit board and they are known to just fail .
    The speaker is only secured with 2 x solder connections and is easy to change if you are handy with a soldering iron .
    I have replaced a few over the years and the job can be done from start to finish in about 45 mins if you are handy with the spanners
    Insignia St Vx-line bodykit , Vx-line 20" alloys , Vxr bumper, Hybrid turbo, Stainless twin exit straight through exhaust
  5. #15
    Feb 2015
    Quote Originally Posted by jon1.9cdti View Post
    Now that's the kind of talk I like lool easy work! Still waiting to fit my new thermostat hopefully tomorrow. And after I check every fuse the car has today. I will strip down the cim next check for any loose connections. Hopefully this is the case
  6. #16
    Swanley , Kent
    129 Post(s)
    Engine : A20DTH
    Mileage : 201000
    Myself and @plasma will be in your rough area on sunday 25th feb ( about 26 miles from you ).
    We can supply and fit the replacement speaker or even a complete replacement cim if you have the security code .
    Obviously there would be a charge for the parts time etc however this would be a fraction of what a garage would charge you .
    We both have tech2 so can read your fault codes etc,
    Pm myself or plasma and i am sure we can sort something out .
  7. Thanks michale_kid thanked for this post
  8. #17
    Swanley , Kent
    129 Post(s)
    Engine : A20DTH
    Mileage : 201000
    I will be very surprised if it is a bad connection , all of the ones i have replaced were faulty/bad speakers .
    Although you may be lucky and have nothing to lose by trying
  9. #18
    Feb 2015
    Still easy enough to to solder new speaker in?? Where did you source a new speaker on your previous repairs?
    I'd rather try this first as sound is the only symptom I have of faulty cim module, I've spent the last two days reading up on changing the whole unit (worst case)
  10. #19
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Sounds very possible - when you had the problem, did the duff speaker generate a "spanner light" or a fault code ?
  11. Likes michale_kid liked this post
  12. #20
    Feb 2015
    Just reading back through the post to try source what speaker to buy and must have missed this reply.. thanks for the offer.. I understand replacing the cim module can be risky business but if it's just strip down replace speaker and refit without any risks then I think I'd be more then capable..
    Still considering though because if it is worst case then I may aswell use your professional skill so I won't be crapping my pants doing it lol.
    Could you inbox be prices please just for speaker change and then a price if it's worst case and needs complete replacement?
    I don't have any codes I don't think as I don't think I got booklet with the car.
  1. Electrical sparking type sound until I use indicators
    By Persia-chris in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2016, 12:58
  2. Judder, dump valve noise, spanner light
    By robster23 in forum Y & Z30DT Specific
    Last Post: 21st May 2013, 09:17
  3. Replies: 3
    Last Post: 26th July 2012, 19:33
  4. Indicators not making an audible sound
    By kevin75 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd May 2012, 23:27
  5. Indicators - no noise?
    By wise1 in forum Insignia car chat
    Last Post: 11th September 2011, 18:10
