Thanks Thanks:  2
Likes Likes:  4
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: No noise/sound from indicators?? & Spanner light
    Regular Member michale_kid's Avatar
    Feb 2015
    Default No noise/sound from indicators?? & Spanner light
    Hi all, a have searched high and low but can't seem to find any information on my car's problem.
    Just bought a 55 signum and whenever I indicate I have to check it's on as their is no sound/noise to say their working..
    Also I have the spanner light on and the garage sad something about the indicators or instrument??
    Anyone have any ideas what's going wrong?
    Sent from my ONEPLUS A5000 using Tapatalk
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    The codes need reading with a proper tool
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Do the "door open" and "lights left on" warning chimes also not work?
    Could be a CIM issue.
    Feb 2015
    Ok I will see if I can find someone with a propper tool or see if a local garage can plug it in..
    I'm pretty sure the car does not beep if I exit the car and leave the lights on but I will double check tonight after my shift.
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Where are you?..maybe someone local could help you out??
    Feb 2015
    Quote Originally Posted by nikroc View Post
    Dunstable (Bedfordshire) is their a section to find out if anyone is nearby?
    Just to confirm the car does not alarm at all when I open the door with the lights left on
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    It does sound like a CIM problem
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I assume everything was working before the door swoop?
    All the old stuff transferred to the new,or vice versa?
    You could always go pay VX.If the worse comes to the worst.
    Feb 2015
    Only bought the car a week ago. Current issues when I got it was heaters only work on no4 and needs new thermostat.
    Then I noticed the spanner light came on. And on way home I found myself checking indicators as couldn't hear it.
    Now the door bleep has been brought to my attention who knows what else.
    Looks like a expensive fix aswell gonna check every fuse and relay in the car today just in case.
    Ps, thanks for your help
    I'll get back to you after I get full diagnostic.
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Hope it was cheap then..think of it this way...at least your getting to know your new car!
  1. Electrical sparking type sound until I use indicators
    By Persia-chris in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2016, 12:58
  2. Judder, dump valve noise, spanner light
    By robster23 in forum Y & Z30DT Specific
    Last Post: 21st May 2013, 09:17
  3. Replies: 3
    Last Post: 26th July 2012, 19:33
  4. Indicators not making an audible sound
    By kevin75 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd May 2012, 23:27
  5. Indicators - no noise?
    By wise1 in forum Insignia car chat
    Last Post: 11th September 2011, 18:10
https:www.vectra-c.comforumshowthread.php231862-No-noise-sound-from-indicators-amp-Spanner-light
https:www.vectra-c.comforumshowthread.php231862-No-noise-sound-from-indicators-amp-Spanner-lightpage2
Vauxhall Insignia no indicator doundsno sound opel Insigniacannot hear indivmcators in car astraopel 2003 vectra no sound when lights are onhttps:www.vectra-c.comforumshowthread.php231862-No-noise-sound-from-indicators-amp-Spanner-lightpage4
