Thanks Thanks:  5
Likes Likes:  1
Results 1 to 10 of 29
Thread: Water in boot with pics added advice needed
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Default Water in boot with pics added advice needed
    Back Windscreen started to mist up and condensation inside of window.Looked at aerial base which has deteriorated and came apart when i checked round it . Stripped out all the back interior panels to get to head lining and found water droplets near aerial all round as you can see in pics .Next step is to seal this .Got some black silicon sealant ,my idea was to remove Ariel completely and seal the base then install Ariel back and seal round the edges on top of the roof .Question would you reinstall the rubber seal under the base and seal the rubber base to the Ariel then seal the complete base to top of the roof or would you discard the seal altogether and seal the Arial straight to the top of the roof and then round the edges.? What a pain to get to the Arial .
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Here's another pic of headlining with some mold near the velcro straps .Pics seem to be coming out upside down for some reason when i upload them here?
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    When you remove the rear drivers side panel be really careful not to pull on the white ribbon cable in the pic as you are in trouble if this gets damaged .Thinking of putting some sealant round the window seals while the panels are off even though they are not leaking .Is it just a matter of undoing the plastic nuts then adding sealant to the black seal round the glass then reinstall .Have not removed Arial yet as time was running out so taped round top of Arial and put some towels in the hole underneath in case it gets through .Any tips appreciated .
    Regular Member RBH's Avatar
    Jan 2008
    Central Scotland
    108 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
    Personally, id keep the old base on if you cant find a replacement and id seal around the existing seal.
    Id use masking tape to give you a guide around the base, when its removed it'll look nice and neat.
    Id also stick some sealer around the hole on the roof before you put the aerial on and secure it in.
  5. Thanks automan thanked for this post
  6. #5
    North West - RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    87 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    the rubber base isn't the primary seal, there is a square 'O' ring around where the aerial goes through the roof. that's the only bit you need to seal.
    because........SIGNUM!
  7. Thanks automan thanked for this post
  8. #6
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Quote Originally Posted by bonehead View Post
    Do you mean seal this part from top of roof outside of car or under where roof lining is ? Cheers
  9. #7
    Feb 2015
    Warrington-ish
    87 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    as Rab said, a bit of sealant around the hole, outside, then put the aerial back in. that should do it.
  10. Thanks automan thanked for this post
  11. #8
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Cheers will do .Thanks
  12. #9
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    or u could buy some silacon sheet use the old ariel seal as a template and make a new seal
  13. #10
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Year : 56
    or u could buy some silacon sheet use the old ariel seal as a template and make a new seal for neatness
  1. Added 12v socket to the boot
    Last Post: 7th August 2014, 14:28
  2. Added a light in the boot
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2014, 21:12
  3. Water Pump stuck in and cracked housing on 2.2 dti advice needed
    By ssonic in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2013, 12:01
  4. Replies: 15
    Last Post: 14th April 2012, 22:11
  5. Advice/Info Needed - Losing Water/Coolant
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:20
