25th January 2018, 07:06
#1
no power to all roof lights
hi i have a vectra cdti 57 plate and for some reason all the lights on the roof are dead including sun visor mirror lights ? the glove box and boot light still work fine so do the 3 switch lights on the front roof light work once i turn on the head lights but thats it have checked all fuses and bulbs but there seems to be no power to the lights
25th January 2018, 07:12
#2
Hi mate sounds like the roof ribbon loom has broken some where down the line you need to drop the interior light at the front and check with a multi meter to see you are getting 12v feed
Post Thanks / Like - 1 Thanks, 1 Likes
25th January 2018, 19:23
#3
yer done that no power but the fuses are fine thanks for reply
25th January 2018, 21:40
#4
hi mate I have a roof ribbon loom if you need one
26th January 2018, 07:34
#5
ok will try to look at this loom /ribbon over the weekend does anybody know were it runs i have a vectra 57 plate hatch am i right in thinking it runs from the fusebox in the boot ? if this is the case is the 1st point it runs the rear roof light ? because if it is that is also dead so am i right in thinking the prob will be between the rear roof light and the main power point in the boot and thank you ram how much you asking for the ribbon ?
19th March 2018, 18:52
#6
Hi,
Anybody got a vectra c estate full loom,,please
23rd March 2018, 11:04
#7
sorted now,,,,,bust loom at the silly join
26th January 2018, 11:02
#8
Hi MATE I AM ASKING £10 FOR THE ROOF RIBBON LOOM YOU ARE JUST BETTER OFF RUNNING A NEW LOOM FROM THE REAR TO THE FRONT INTERIOR LIGHT THE ORIGINAL IS TAPED ONTO THE ROOF AND WILL BE A PAIN TO REMOVE YOUR ARE BETTER OFF LEAVING IT IN PLACE AND RUNNING THE NEW LOOM AGAINST THE OLD ONE UNLESS YOU ARE GOING TO REMOVE THE COMPLETE ROOF LINING THEN REPLACING OLD WITH THE NEW LOOM
28th January 2018, 11:45
#9
Originally Posted by
RAM
sent you a pm mate
26th January 2018, 20:58
#10
cheers ram i sent you a pm
