Thanks Thanks:  5
Likes Likes:  9
Results 1 to 10 of 27
Thread: no power to all roof lights
    Regular Member madmark's Avatar
    great yarmouth
    Default no power to all roof lights
    hi i have a vectra cdti 57 plate and for some reason all the lights on the roof are dead including sun visor mirror lights ? the glove box and boot light still work fine so do the 3 switch lights on the front roof light work once i turn on the head lights but thats it have checked all fuses and bulbs but there seems to be no power to the lights
    Jan 2015
    walsall
    Vehicle : vectra
    Trim : sri
    Engine : 1.9 CDTI 150 BRAKE
    Year : 07
    Hi mate sounds like the roof ribbon loom has broken some where down the line you need to drop the interior light at the front and check with a multi meter to see you are getting 12v feed
  3. Thanks madmark thanked for this post
    Likes madmark liked this post
  4. #3
    great yarmouth
    yer done that no power but the fuses are fine thanks for reply
  5. #4
    Jan 2015
    walsall
    Vehicle : vectra
    Trim : sri
    Year : 07
    hi mate I have a roof ribbon loom if you need one
  6. Likes madmark liked this post
  7. #5
    great yarmouth
    ok will try to look at this loom /ribbon over the weekend does anybody know were it runs i have a vectra 57 plate hatch am i right in thinking it runs from the fusebox in the boot ? if this is the case is the 1st point it runs the rear roof light ? because if it is that is also dead so am i right in thinking the prob will be between the rear roof light and the main power point in the boot and thank you ram how much you asking for the ribbon ?
  8. #6
    Jan 2015
    walsall
    Vehicle : vectra
    Trim : sri
    Year : 07
    Hi MATE I AM ASKING £10 FOR THE ROOF RIBBON LOOM YOU ARE JUST BETTER OFF RUNNING A NEW LOOM FROM THE REAR TO THE FRONT INTERIOR LIGHT THE ORIGINAL IS TAPED ONTO THE ROOF AND WILL BE A PAIN TO REMOVE YOUR ARE BETTER OFF LEAVING IT IN PLACE AND RUNNING THE NEW LOOM AGAINST THE OLD ONE UNLESS YOU ARE GOING TO REMOVE THE COMPLETE ROOF LINING THEN REPLACING OLD WITH THE NEW LOOM
  9. Thanks madmark thanked for this post
  10. #7
    great yarmouth
    cheers ram i sent you a pm
  11. #8
    great yarmouth
    Quote Originally Posted by RAM View Post
    sent you a pm mate
  12. #9
    great yarmouth
    ok so have a 1 live and a earth at the light with all the doors shut the passenger side map light works only but goes off if you try to switch any other lights on by the switches or if you also open the door this 1 light goes off ?
  13. #10
    great yarmouth
    could this be a relay problem as if ime right when u unlock and lock the car the lights come on and fade off is that a relay that does that power ? anybody know and where to locate it thank you
  1. Upgrading roof lights and side lights to led
    By Pete80 in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2015, 13:12
  2. roof console maps lights etc
    By Dog_Book in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2013, 17:11
  3. Replies: 7
    Last Post: 15th May 2013, 17:27
  4. Roof Console with Map Lights
    By SRiXPT in forum Parts for sale
    Last Post: 16th April 2011, 11:55
