Results 1 to 10 of 11
Thread: 12v permanent live needed @ AUX modulator
    Regular Member rmsNoel's Avatar
    May 2014
    in my garage
    Vehicle : vectra Cdti
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    Default 12v permanent live needed @ AUX modulator
    I bought a FM modulator for Christmas (iSimple from bass junkies) and I need a permanent 12v live around or near the dash. I have a switch inline on the unit so I can attach it to a permanent live.
    I have read through many many threads here about switched lives and wake up signals with half and full canbus. I want to avoid a switched live so I can easily use this unit with keys out or at acc1
    May 2014
    in my garage
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    I have a 2005 design with cdc40 opera.
    May 2014
    in my garage
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    Regular Member pattz123's Avatar
    Motherwell
    14 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    Quote Originally Posted by rmsNoel View Post
    Passenger side of dash fuse board, 2007 Vectra Facelift, ive got my dash cam wired there but only issue is battery drain if left for over 3-4 days.
    Jan 2012
    Blandford forum dorset
    Vehicle : Vectra c
    Engine : Z18XER
    Mileage : 89000
    Which one would you use for a switched live?
    May 2014
    in my garage
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    Quote Originally Posted by Slick_richie View Post
    F22 should be for the cigarette lighter which is switched live. You might need to double check in your user manual.
    There's a thread here called dashcamhard wired
    May 2014
    in my garage
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    The green 30a on the third row up at the right hand side
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    164 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Or a multimeter
    Teapot Tuned 260/300
    https://www.vectra-c.com/forum/calendar.php
    May 2014
    in my garage
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    Quote Originally Posted by Dog_Book View Post
    Or a multimeter
    What's the multimeter for?
    Jan 2012
    Vehicle : Vectra c
    Engine : Z18XER
    Mileage : 89000
    What hard wire kit do you guys think I should get. I'm having trouble on figuring what one to get because these a mini fuse?
  1. permanent fused live in the rec
    By Jules_Signum in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2015, 18:57
  2. permanent 12v live
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2012, 17:53
  3. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  4. permanent live in the boot
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 07:02
  5. permanent live
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2008, 16:25
