Thread: alternator wiring
    Full Member
    Nov 2017
    wiltshire
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvc
    Default alternator wiring
    hi all
    I need to replace the alternator on my vec c I need a 120 amp one and the one fitted to the car has 1 big threaded post and a small plug a mate of mine has a used alternator from an astra that is the same part number and has the large threaded post but instead of a plug it has a small threaded post can I chop of the plug and fit a ring terminal?
    Last edited by xantiaman1; 6th December 2017 at 01:28. Reason: incorrect information
    Administrator plasma's Avatar
    On the Forum
    425 Post(s)
    Engine : 150
    Mileage : 74000
    That's what we did on mine. Removed the two pin plug (Only one wire used) and put a ring terminal on it
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    so u can covert a bosch alternator to a denson type fitting if so can you tell me how to do this
    On the Forum
    425 Post(s)
    Engine : 150
    Mileage : 74000
    I have already. Read above again
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Year : 56
    it just has the male terminal on it, so which of the 2 terminals do i conect to the o ring terminal
    On the Forum
    425 Post(s)
    Engine : 150
    Mileage : 74000
    There is only one wire on the two pin plug
  1. denso alternator to bosch alternator
    By paula9568 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2016, 19:27
  2. what amp alternator
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2013, 22:56
  3. Alternator HELP
    By dezzyb66 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2012, 14:25
  4. Alternator on way out?
    By dittohead in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2010, 21:34
  5. alternator
    By gralph in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2009, 18:02
