Likes Likes:  5
Results 1 to 10 of 13
Thread: Buying decision - Zafira 2.2 direct, petrol
    Dec 2014
    Default Buying decision - Zafira 2.2 direct, petrol
    Hi guys. I have a Vectra C which I got after selling my Astra. Recently I been thinking of gettinu g a Zafira for family reasons. I was offered one on the cheap (2006 model, 2.2 direct, petrol engine). However it has been grounded for some time after the engine collapsed. Enquiry revealed that that was the 3rd engine replacement on the vehicle.
    Now, is there a problem with the 2.2direct? Should I run away even though it was going for cheap? Advice appreciated, thanks.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    So its now on its fourth engine?...overall miles on the vehicle?..are they confirmed?...I ask as the various consumables may well be past there best so maybe factor in those things too...
    Is the rest of the vehicle/gearbox in ok condition?..what is cheap?..
    Consider your going to be putting another engine in and is likely to be second hand...unless your going to have one reconsitioned...
    Personally id run away and find something with a known history ..but thats me.
    Dec 2014
    Thanks nik. Yeah it's on it's fourth engine. 100miles on the clock. Gearbox okay. However the mechanic was saying something the cooling system (radiator, leaking pipes) as the cause of the engine failure. Worth mentioning that the last two engines were fixed and replaced within months of each other (1 year overall).
    Owner asking for N500k (Nigerian naira, I live here ☺). That's roughly $1,300.
    11 Post(s)
    Usual problems with the 2.2 engine is the cam chain tensioner can stick and subsequently fail. Catastrophic engine damage if the chain breaks.
    Other problems are the high pressure fuel pump, and fuel regulator. Doesn't require a replacement engine though.
    You need to establish why the engine has been changed time and time again. Lack of any maintenance by the previous owner(s) for example.
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    I'd personally look at other options and leave this to someone else.
    Alan
    VIP-Member Rhodie's Avatar
    Oct 2014
    Ossett, W Yorkshire
    23 Post(s)
    Blog Entries
    1
    Engine : 1.9 CDTI 150
    Mileage : 75000
    Barge and Pole spring to mind. Run away from this one if I was you mate
    2007 1.9 CDTI Elite hatch 150. 2 x led boot lights, HID's, aux, comfort unit, circular wheels, overhead roof and see through windscreen
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    22 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    I don't know much about the 2.2 direct engines but i would look at another car... and with what you've just stated i would be very reluctant looking at a car with that engine... but that is just me.
    Full Member RBH's Avatar
    Jan 2008
    Central Scotland
    103 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
    Quote Originally Posted by al21784 View Post
    I
    Yeah...the breakers yard.
    Jan 2008
    Central Scotland
    103 Post(s)
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
    I
  10. Likes AL21784 liked this post
  11. #10
    11 Post(s)
    Quote Originally Posted by RBH View Post
    This place is becoming so empty that echo's can now be heard
  1. Replies: 6
    Last Post: 26th January 2014, 20:31
  2. Vectra c signum zafira b petrol 2.2 fuel pump
    By MUNGIS in forum Engine & Drivetrain
    Last Post: 2nd January 2014, 19:58
  3. signum 2.2 direct petrol direct help
    By haden540 in forum Engine & Drivetrain
    Last Post: 28th June 2013, 17:04
  4. Replies: 15
    Last Post: 21st February 2013, 09:31
  5. buying a Zafira
    By IA76 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 20:45
