Thanks Thanks:  3
Likes Likes:  3
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Coolant draining
  1. #11
    Dec 2017
    Towcester
    Vehicle : Vectra 1.9 cdti
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    The gauge on the dashboard doesn't move at all.
  2. #12
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    You could have a look in the test menu on the display and watch the coolant temp - this will give you a good idea if the thermostat is goosed as you'll see it warm up quite quickly from cold...
    https://www.vectra-c.com/forum/showt...y-(-Test-Mode)
    Sounds like it's the gauge or wiring that's at fault to me if the heater is blowing warm. An old trick I used to do to test the wiring and gauge was take the plug off the temp sensor and ground it you should see the needle swing all the way to the red - that's in the days of single pin sensors though, sure the vec has a 2 pin one!
  3. Thanks Darter thanked for this post
  4. #13
    Oxfordshire
    11 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by Darter View Post
    Hi mate. I've had it out for a 10 mile run. The heater in the car did get warm, and so did the hoses, but I could comfortably hold my hand on them, and they didn't seem excessively hot, but I've never owned a diesel before and i'm not sure if they get as hot as petrol engines.
    They get as hot as petrol engines. Just generally slightly longer as they're more thermally efficient than petrol engines.
    Bearing in mind the gauge minimum reading is something like 70 deg C, that doesn't necessarily mean that it's a faulty gauge or sender. It might just be the engine isn't getting all that warm, especially If you can comfortably still hold your hands on the hoses. If both the in and out hoses feel about the same temperature, then this suggests the thermostat is stuck open and not doing its job. The in hose should feel cooler than the out one.
    As suggested by someone else, if you've got he right stereo, go into the test mode to check the digital readout of the temperature.
  5. Thanks Darter thanked for this post
  6. #14
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Thanks guys.
    Sounds like the thermostat is my next job, and hopefully that'll sort it. I'll let you know how I get on.
    Thanks again for the advice.
    Alan
  7. #15
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Thanks guys.
    Alan
  8. #16
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Just thinking that I have the original sensor that I replaced, if I connect that to the wiring and then dipped the probe end into hot water I should se the gauge move. If it doesn't it must be the gauge.
  9. Likes DG36, Big Dave liked this post
  10. #17
    Dec 2014
    North Lincolnshire
    Vehicle : vectra
    Trim : sri
    Engine : 1.8
    I have a fault like that. The gauge doesn’t move at all unless I’m sat in traffic on a warm day, then it will go up to about half way and drop back down once I start moving again.
  1. battery draining
    By philyo in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2014, 18:59
  2. Help draining oil!
    By owen_999 in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2013, 23:06
  3. Coolant plug for easy draining
    By rajveer.sandhu in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2013, 20:28
  4. Battery draining. HELP PLEASE
    By Jaredryder in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2013, 17:05
  5. Draining Coolant
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 21:25
