Thanks Thanks:  3
Likes Likes:  3
Results 1 to 10 of 17
Thread: Coolant draining
    Dec 2017
    Towcester
    Vehicle : Vectra 1.9 cdti
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Default Coolant draining
    Hi guys.
    Nice simple one, but I don't want to do a lot of work if I don't need to. I need to change the temp sensor on my 2007 1.9cdti. The question is, do I have to take off the bottom trays to access the drain tap, or can you get at it another way. Any advice is welcomed.
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    You can drain the coolant by removing the top pipes to the expansion tank, then tilting the tank to pour it out, once you've removed some you can remove the bottom pipe and a 2L bottle fits down to enable you to drain a few litres out. changed a thermostat the other week and only lost a couple hundred ml that way.
    Alan
    VIP-Member Rhodie's Avatar
    Oct 2014
    Ossett, W Yorkshire
    23 Post(s)
    Blog Entries
    1
    Engine : 1.9 CDTI 150
    Mileage : 75000
    Quote Originally Posted by al21784 View Post
    Alan
    As it was my thermostat he changed, I can vouch for that. I bought a 2 litre bottle of coolant just in case, and we only had to use a fraction of it
    2007 1.9 CDTI Elite hatch 150. 2 x led boot lights, HID's, aux, comfort unit, circular wheels, overhead roof and see through windscreen
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Thanks fellas. I managed to change the sensor, but my temp gauge still doesn't move at all. Any suggestions what might be the problem?
    Jun 2007
    5 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    Have you change the thermostat?
    Alan
  6. Thanks Darter thanked for this post
  7. #6
    11 Post(s)
    Quote Originally Posted by Darter View Post
    Thermostat sounds duff.
    What made you think it was the sensor?
  8. Likes Darter liked this post
  9. #7
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    A mechanic told me it was the most likely cause, and it only cost a tenner from Europarts so I thought it was the best option to start with. Could there be an electrical fault?
  10. #8
    11 Post(s)
    Is the heater getting hot? How hot is the return hose from the engine to the rad after it's been running a while?
    Not while stationary btw, after the car has been driven for a short while?
  11. #9
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Hi mate. I've had it out for a 10 mile run. The heater in the car did get warm, and so did the hoses, but I could comfortably hold my hand on them, and they didn't seem excessively hot, but I've never owned a diesel before and i'm not sure if they get as hot as petrol engines.
  12. #10
    Jun 2007
    5 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    My 1.9 16v sits around 85-90 degrees, and mine warms up very quickly. If it’s bit showing on the gauge or getting warm then replace your thermostat.
    Alan
  1. battery draining
    By philyo in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2014, 18:59
  2. Help draining oil!
    By owen_999 in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2013, 23:06
  3. Coolant plug for easy draining
    By rajveer.sandhu in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2013, 20:28
  4. Battery draining. HELP PLEASE
    By Jaredryder in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2013, 17:05
  5. Draining Coolant
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 21:25
