Results 1 to 10 of 13
Thread: 1.9 120 tappet noise?
    Carnoustie
    Default 1.9 120 tappet noise?
    Hi guys, Just got a 1.9cdti 120 Zaffy with 78k miles never noticed this until after I bought it but after a cold start I get a ticking noise at idle which goes away with a slight rev and once warmed it goes away completely. Thinking maybe the valve clearances need checked? I/m going to do a oil and filter change anyway.
    I have gone to this from a very good running vec 150 although the 120 is fairly nippy it's for sure noisier than the vec! more rattly when accelerating is this normal?
    Thanks Ronnie
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    18 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Could it be chains and adjuster/tensioner?...tbh i have no idea on a diesel..see what its like after an oil n filter change...
    Carnoustie
    Quote Originally Posted by nikroc View Post
    No chains on this engine, but thanks for the reply
    Nov 2007
    DERBY
    18 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Without a soundfile/hearing it its all guesswork BUT if you think its tappets then I would use a quality engine flush and decent oil on your intended change.
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    if u dont know the history of the engine a engine flush could damage the oil seals so i would just change the oil and filter
    Nov 2007
    DERBY
    18 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    how could a flush damage the oil seals?...I understand some people feel that by using a flush they may remove crud etc that has built up over the years and therefore potentially cause problems ...
    I have alway's used a flush on every car I have ever bought,worked on and will continue to do so BUT I appreciate its a choice/preference thing
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Year : 56
    like u said crud could block a oil gallery best be safe than sorry, that why i change my oil every 6 months
    Nov 2007
    DERBY
    18 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Oil n filter changed every 6 months here too
    Regular Member MattD99's Avatar
    Aug 2017
    Chester
    Trim : Exclusiv
    Engine : 1.9 CDTI (120) 8v
    Mileage : 148,000
    My vectra 120 CDTI seems to do the same thing. Like a rattle from behind the dashboard?
    Sent from my iPhone using Tapatalk
    Northern Ireland
    Vehicle : 05 1.9cdti 120bhp
    Trim : Standard hatchback,VXR alloys.
    Engine : Z19DT
    Mileage : 97000
    I get an occasional ticking type noise when I first start the car and mine is coming from the alternator pulley.
  1. Z19dt 8v tappet adjustments query help or advice
    By ianwat23 in forum Engine & Drivetrain
    Last Post: 29th August 2016, 07:45
  2. Vxr loud exhaust noise on start up. How to reduce noise and not annoy neighbours
    By john is200sport in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2016, 17:25
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. GSi V6 3.2 hydraulic tappet change.
    By Tennants in forum Engine & Drivetrain
    Last Post: 13th June 2010, 14:29
  5. 120bhp 8v CDTI tappet noise on new engine
    By StratApproach in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2007, 23:19
