Likes Likes:  10
Results 1 to 10 of 16
Thread: Wife's stolen the Vectra - who can help with her Astra ?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Default Wife's stolen the Vectra - who can help with her Astra ?
    Last week she broke down - wouldn't accept a push start from me, and I had the RAC out ( well an 'associate' independent )
    Basically the car just died as she pulled away from a junction. Engine's the same Z18XER as my Vec, All the dash lit up, and when you tried to start it got click, click, click - strangely though the lights don't dim. RAC said battery, and as it was original on a 57 sounded likely and changed it.
    Darn thing's just done it again, and started first time with a jump from the Vectra. I tested the alternator and was getting 14.1v
    Oh - no codes logged BTW
    Any ideas ?
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 192000
    Battery is good and the alternator is good, then its your starter motor.
    Alan
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    But would a dodgy starter cause it to cut out mid journey which is what initiated both breakdowns ?
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    9 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Try creating another earth from the engine to the chassis/body and see if that makes it any better!
    Sent from my SM-G930F using Tapatalk
    I am a Mechanic!
    However my advice is followed at your own risk!!
    Black Vec C CDTi 150.
    Apr 2013
    Luton
    Vehicle : Vectra C Hatchback
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Coil Pack? (should create a code though?)
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Well its completely horlicksed now. No attempt to start - had the RAC out for 2 hrs and recovered home. No comms with the ECU via diagnostic socket, and no signal from ECU to start relay
    BIG trouble
    South Central - Assistant RO Matty2Fatty's Avatar
    Mar 2014
    West London
    73 Post(s)
    Trim : Elite Estate
    Engine : 1.9 CDTi 16v 120 BHP
    Not a faulty replacement battery? Had a few of those on my other cars which was annoying to say the least
    Click HERE to see up and coming events
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    I've had the ECU in the ECU doctors - it powered up ok, so I thought that was the culprit BUT when I tried a replacement cleared UEC, expecting to have comms at least, its still failing to link at the EOBD socket. Ive done all the checks I can with reference to circuit diagrams he provided and the ECU is getting both ignition and permanent live, and the ECU relay wires pass con checks. All fuses pass - get same reading from either UEC albeit the 'new' one needs coding so shows as unmatched.
    So, can an ECU power up, be accessible on the bench, but not register on the car ?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Sounds like Teapot or Paulvectrac type of question to me.
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Quote Originally Posted by JagRigger View Post
    So the original ECU leads to cut outs but with no starting its unlikely to be heat related,
    Second ECU no comms and original tests fine on bench.
    How do the harnesses and connections look?
    As VMB said have you ruled out earthing probs?
    Tricky one, let us know.
  11. Likes Grumpy1954 liked this post
  1. Astra (recommend an Astra for my wife please)
    By Graham35 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2015, 19:36
  2. STOLEN - MK1 Astra Estate
    By Keif in forum General Motoring Chat
    Last Post: 3rd January 2012, 23:07
  3. Not the Vectra but the wife's Astra..
    By macdad in forum The 'Off Topic' room
    Last Post: 1st October 2011, 09:07
  4. stolen Astra VXR Nurburgring
    By lizard in forum General Chat
    Last Post: 4th October 2008, 14:10
