Results 1 to 3 of 3
Thread: Fault code p0234 vauxhall signum 1.9 150
    Dec 2015
    Woodhall Spa
    Trim : Elegence
    Engine : 1.9cdti
    Default Fault code p0234 vauxhall signum 1.9 150
    Please help after giving the car a good going it retreat's and falls into limp mode. It can be cleared by Thurning the key. Was wandering what it could be, I seem to be suffering from poor mpg too could this all be caused by the overboast problem. Any ideas?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it's called limp mode... the ECU notices an over-boost and decides to rain it all in... as soon as you turn the car off it goes back to normal... over-boost means that either the intake is dirty/ one off the boostpipes is leaking or comes off/ a leak in the vacuum lines/VNT mechanism on the turbo is stuck/leak in the intercooler /or the turbo actuator or boost valve has given up... it could also be a dirty MAF or boost sensor so all in all you need to check the system.... for all those bits.
    nothing too difficult but very labor intense i would start with checking the big boostpipes/ all the vacuum pipes/ than check the MAF and Boost sensor (they can be cleaned with an electrical cleaner) than i would take of the front bumper and check the intercooler... but in most cases it is one of the pipes..... if that all seems fine... than you can clean the VNT on the turbo with a foaming oven cleaner such as MR Muscle(meaning you need to take of the hotside of the turbo, remove the downpipe, and spray it right into the back of the housing where the VNT is than work the lever until it feels smooth when it is close it all back up and go for a run of at least 40 miles in 3th gear so the turbo gets red hot and burns the ovencleaner and all the soot off)
    the turbo actuator can be tested with a vacuum pump but if you don't have that it's best to have that checked by a garage/ and the Boost valve is the one that connects to the turbo actuator... it can be cleaned with electrical cleaner spray it in the bottom and top pipe and watch all the dirt coming out while you do so... you can blow on both pipes to make sure it works but usually the electrical cleaners pressure is enough to notice if it isn't functioning properly.
    But knowing the vectra's the chance it is just a boost leak is greater than the VNT mechanism being stuck.
    Dec 2015
    Woodhall Spa
    Trim : Elegence
    Engine : 1.9cdti
    Thank you for the reply a great bit of information will get onto it tomorrow
  1. Vauxhall vectra C 2.0 DTI P1811 fault code.
    By ausura in forum Engine & Drivetrain
    Last Post: 9th June 2016, 08:06
  2. P0420 Fault Code - interesting article re this common fault
    By alcutler in forum General Motoring Chat
    Last Post: 27th March 2015, 23:45
  3. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  4. Vauxhall Signum Diesel 05 plate fault code P1483
    By cookie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th January 2013, 19:28
  5. VAUXHALL VECTRA C compatible OBD2 FAULT CODE READER
    By big rich in forum Parts for sale
    Last Post: 16th February 2009, 02:25
