Thanks Thanks:  1
Likes Likes:  3
Results 1 to 8 of 8
Thread: 2 bulbs not working but no warning on display?
    Jul 2014
    Coulsdon, Surrey
    Vehicle : Vectra SRi T estate
    Engine : 2.0 Turbo
    Year : 2008
    Default 2 bulbs not working but no warning on display?
    I have a dodgy rear tail light so used to see regular warnings on the display about failed bulbs - a quick knock on the side of the light unit usually sorts it for a while
    Having not seen any bulb failure messages for a while, I thought I'd check myself that all bulbs were working. As usual, the suspect tail light wasn't working and neither was the NSF parking light.
    I wonder why I'm not seeing any info about these bulb failures?
    Full Member
    Jan 2008
    93 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : ....
    Year : .....
    I would give the contacts a good cleaning up with Emery paper and make sure the clip is tight.
    As for the warnings????
    It'll be like the missus, fed up telling you lol
  3. Thanks 08estate thanked for this post
    Likes dougie89, Matty2Fatty liked this post
  4. #3
    Jul 2014
    Coulsdon, Surrey
    Engine : 2.0 Turbo
    Year : 2008
    Thanks RBH. It does seem like it's got the hump about the tail light!
    The other parking light failed this evening - the warning appeared on the display and the failed bulb symbol lit up on the dash. Good to know at least some of the warning system is still working
  5. Likes RBH liked this post
  6. #4
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    Don't the rear lights have 2 x Bulbs in them? if one fails, the other immediately takes over. I could be wrong on this however I'm sure I've seen 2 in there..
    Alan
  7. #5
    Oct 2013
    Derby
    188 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Fun over here if you want to confuse yourself
    http://www.vxronline.co.uk/forum/sho...rear-lamp-bulb
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  8. #6
    Oxfordshire
    11 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by al21784 View Post
    when everything is ok - from top to bottom
    Indicator
    Tail light / brake light
    Tail light
    Fog tail light (drivers side only)
    Reversing light
    But when the brake light fails:-
    Indicator
    no light
    Reversing light
    The bulb warning system should pick this up though.
  9. #7
    Jul 2014
    Coulsdon, Surrey
    Engine : 2.0 Turbo
    Year : 2008
    Indicator
    Tail light
    Reversing light
    Indicator
    no light
    Reversing light
    Thanks for the replies It's not quite the same on the estate. I believe one of the lights that are mounted on the tailgate becomes the brake light when the 'proper' brake light (in the body mounted light unit) fails.
    I started the thread mainly because of the lack of warnings on the dash or the display screen about the non-working bulbs. Still not sure why it's warning about some failed bulbs but not others
  10. #8
    Oct 2013
    Derby
    188 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Still going strong here http://www.vxronline.co.uk/forum/sho...rear-lamp-bulb
    Do what i did and i posted in my diary, clean up and change the lot for long life lamps
  1. In tacho warning display not working
    By oldyam in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2017, 13:59
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. CD30 Replacement bulbs for display
    By Andymouse in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd August 2012, 17:12
  4. display not working
    By lostit523 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2011, 22:52
  5. Radio display bulbs?
    By joec in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2007, 22:25
