Likes Likes:  2
Results 1 to 10 of 14
Thread: Limp mode and fault codes
    Regular Member Honeypotshots's Avatar
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    Default Limp mode and fault codes
    So this morning while heading up to my friends the engine management light came on along with the exhaust light and then the car went into limp mode.
    I went to the nearest garage and grabbed a man with a code reader and here are the results : the car is still under warranty
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    they could be stored fault code so they need to be cleard then read again to see which remain
  3. Likes Honeypotshots liked this post
  4. #3
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    Thanks for the tip I’ll give it a go
  5. #4
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    Quick update, looks like my mass airflow sensor picked up the fumes from a dirty van in front of me that was blowing thick black smoke out the back end. Since I have had all codes reset ( thank you for that advice) and retested and now no faults present. Took me all day to get this sorted driving up and down roads to see if limp mode restarted but for the grand total of £30 I think I got off light
  6. #5
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    So not the mass sensor picking up fumes! A week later same thing happens ( although was driving perfect during that week) so now back in the garage to be checked over and fixed
  7. #6
    Full Member MrMarlow's Avatar
    Jan 2017
    Leicester
    Trim : Exclusiv
    Engine : 1.8
    Quote Originally Posted by Honeypotshots View Post
    At least this time your fault codes will all be relevant.
    Worth noting, I generally use a friends cheap £25 diagnostic kit and its always bought up the code. On the off chance you may need to read codes in the future, its probably worth a look for one cheap.
  8. Likes Honeypotshots liked this post
  9. #7
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    Quote Originally Posted by MrMarlow View Post
    Thank you, yes I was going to look at getting one ( I’m turning into quite the little mechanic now lol)
    so after diagnosing there seems to be no actual fault ( we shall see) there was a loose wire, so more driving and see if it happens again
  10. #8
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    So far so good lol but to save myself further spending, anyone no of a good cheap code reader? That I can use to reset the codes myself if needed. Thanks in advance
  11. #9
    Oct 2017
    Gloucestershire
    Engine : 2.8 turbo
    Year : 06
    The saga continues...... my car has gone into limp mode 3 times now, each time it’s coming up with maf sensor. The wires were loose so have been re crimped, but again I find myself in limp mode, I have noticed that each time this happens it’s been a cold morning with frost on the ground. Do any of you think my maf sensor needs cleaning? From the service receipts the maf was replaced 8 months ago
  12. #10
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    194 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Replaced with genuine?
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  1. Fault p0409 Limp mode egr related
    By Scottfreeman in forum Y & Z30DT Specific
    Last Post: 3rd July 2015, 21:17
  2. Limp mode with P2279, P1120 and P1122 codes
    By popeye76 in forum Engine & Drivetrain
    Last Post: 8th May 2014, 12:01
  3. Intermittent limp mode and codes...
    Last Post: 20th May 2013, 18:09
  4. Fault code and limp mode
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 7th February 2012, 20:58
  5. car keeps goin into limp mode! No codes! No idea whats up??
    By richiem in forum Engine & Drivetrain
    Last Post: 19th January 2012, 04:43
