Thread: Gear box oil
    Regular Member fellie's Avatar
    Lincoln
    Default Gear box oil
    What is the general consensus on manual gearbox oil changes ..
    how often, what oil, does it need new screens/ filters, etc ..
    tia
    in reality, they're sealed for life and shouldn't need touching..just watch for any leaks..no leaks means no topups..
    Lincoln
    how odd we've been discussing the importance of engine oil, in several threads, and gearbox oil seems unimportant lol ..
    sealed for life is a good theory , but no oil lasts forever .. as my vec cdti is now at 70,000 miles, Id assume a good dose of clean gearbox oil a good tonic for another trouble free 70k .
    I know as a previous BMW 5 series owner, and forum admin at bmw5.co.uk, that BMW state autoboxes are sealed for life, but for £100, fresh oil and a new screen filter can eliminate stubborness to shift, and improve its overall efficiency.
    yep, but as there is no carbonisation of the oil as there is no combustion going on ( like in the engine) then the oil will never get 'dirty'.. a magnet in the box traps swarf and the oil goes on forever..
    it used to be possible to drain the boxes by taking the diff pan off, a bit extreme but the only way..then re-filling via the breather on the change housing..but these new boxes should be treated as sealed..
    Lincoln
    ahh fair points.. I always imagine the oil getting messed up like car oil
    might grease the gear change linkages for a 'possibly' smoother change
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
