Thanks Thanks:  1
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: OMBUDSMAN, here I come...
  1. #11
    VIP-Member jaguser's Avatar
    Jul 2015
    Brockworth
    149 Post(s)
    Vehicle : insignia
    Trim : Sri
    Engine : 2.0cdti 160
    Mileage : It depend
    think u looking for this.gps doesnt have it but for sure they can get it.if u order from my link min 2 pieces
    https://www.online-teile.com/opel-er...862432900e0e44
    also i think i found it here
    https://www.ersatzteile-original.com...8::192398.html
  2. #12
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    @Critch tracked down something like this for me in April this year from Lookers Deeside.
    Their invoice shows part number as 9202092 though so I'm not sure if this was a "non stock" code or Genuine.
    My pipe came apart at the joint and hadn't been replaced when the thermostat and housing were changed a couple of years ago.
    Got to be worth a call ?
    Good Luck
  3. #13
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    That pipe will come off with patience.
    i did woodys years ago absolutely clueless at that point about anything to do with gsi.
    new stat fitted and pipe has been fine.
    ok we had to replace the rubber hose from rad to that pipe.
    but considering the amount of works that's been done on that engine I don't think that's a bad thing.
    dealer actually had that rubber hose in stock.
    that metal pipe contains a couple o rings
    so go find a decent independent garage worst case is it'll need new new o rings popping on.
  4. #14
    bexhill on sea
    Thank you all so much for your input, did lots of phone calls to Germany today but no luck with the pipe.
    Critch, will any type of 'O' rings do the job or do they need to be high temp sort of thing. Should i just buy a selection from ebay etc if they are not specials.
    Roughly what sizes too...???
  5. #15
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Year : 2003
    Mileage : 256,000
    Hmmmm. I should have kept my old one that I removed almost four years ago.
    I guess you will need to clean yours up carefully, find some O-rings and re-use it. Vapour cleaning seems to be great for alloy components. I know someone that can do this but it'd mean your car being out of action for a bit. Let me know if you're interested.
    Paul
  6. #16
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I feel your pain on this, a decade or 2 back I had a Vauxhall Royale Coupe, one owner before me and generally in good condition. The old 2.8 straight six was quite fun when the boy racers with their 1.0 buzzbombs tried it on. Then one year it went down on handbrake on MoT, one side not working properly. Took it to bits (discs all round, handbrake drum inside disc hub) and found a small w shaped metal clip that guided the handbrake cable had rubbed on something and worn enough not to do it's job.
    Tried all over to get one, even considered having one made, vauxhall/Opel said the part wasn't well stocked when the cars were new, the only way to get one was buy anopther car and hope it had one in good condition. At the time, there were only around 70 left in UK, chances of someone letting me dismantle one for spares was limited, local engineering places didn't want to know. had to take it off the road and sell it spares or repair. "For want of a nail....." At least you've got possibilities.
