Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 14
Thread: Steering rack identification for replacement
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Steering rack identification for replacement
    A friend of mine is having to replace his steering rack on his 2004 1.9 150 as its leaking bad a cutting out intermittently while driving. We topped the fluid up as it was almost bone dry but its pretty much leaked it out again.
    I've put his VIN number into ECAT and its come up with 2 choices which have different IDENT codes and seem to be LHD
    2 93172263 5900218 GEAR,ASSY.,STEERING,LESS TIE RODS,LHD (IDENT PP) 1
    6 93172264 5900219 GEAR,ASSY.,STEERING,LESS TIE RODS,LHD (IDENT PR) 1
    The only difference we thought was just where the power steering fluid res was located (his is attached to the rack and NOT behind the wing)
    I cant seem to find a definitive answer on how to find out which one he has and therefor needs. The only solution i've read on here is to take the old one out and look on the numbers on the rack. The only problem with this is that we need to take out and replace in 1 go as the car is needed daily.
    Can anybody help?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    you could go ask Vauxhall....or if its down to a choice of two buy them both and return the 'wrong' one..
    Administrator plasma's Avatar
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    is it a base model or an SRi?
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Quote Originally Posted by plasma View Post
    It's an SRi with traction control ( I think they call ESP )
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    pm me reg number or vin number
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    93172266 59 00 221GEAR, ASSY., STEERING, LESS TIE RODS, RHD (IDENT QR)Z16XE[L91], Z16XEP[LJ7], Z18XE[2H9], Z18XER[2H0], Z18XEL[L97], Z19DTL[LPP], Z19DT[LPM], Z19DTH[LRD] (C) 31096517-
    (C) 38085652-
    Sri with ESP for lowered and non-lowered chassis
  7. Likes justin32 liked this post
  8. #7
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    (C) 38085652-
    Is the part number the number ending 2266 the one we need?
    I can still message you his vin number if you need it?
  9. #8
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    ok, message me vin number just to be sure
    and yes the number in bold was the part number
  10. #9
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    93172265 59 00 220GEAR, ASSY., STEERING, LESS TIE RODS, RHD (IDENT PQ)Z16XE[L91], Z16XEP[LJ7], Z18XE[2H9], Z18XER[2H0], Z18XEL[L97], Z19DTL[LPP], Z19DT[LPM], Z19DTH[LRD] (C) 31096517-
    (C) 38085652-
    Ident PQ
    is the one listed for the chassis number you messaged me
  11. #10
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Thank you for your help mate
  1. Steering rack replacement help?!
    By Ozyboyross in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 1st August 2014, 17:56
  2. Steering rack replacement!!
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2014, 07:31
  3. Steering rack
    By jamiedvvt in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2014, 17:30
  4. Vectra c steering rack dashboard steering wheel
    By Martinlw in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2013, 23:05
  5. Steering rack replacement - is it DIY?
    By Mark_k in forum Engine & Drivetrain
    Last Post: 2nd August 2012, 20:28
vectra c steering rack replacement
