Thread: Interior light upgrade without the loom?
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Interior light upgrade without the loom?
    Has anyone done this upgrade to a face lift without the wiring loom in the roof? It's a simple enough job to run a wire from the front lights to the rear but how do you connect to the rear light without the correct plug for the end of the wires?
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    I'm thinking about doing it this way, I'm guessing some form of soldering will be required.
    Regular Member andyfinch's Avatar
    There Abouts
    I had the same problem, so i carefully soldered each wire to the correct spot on the rear light and then seperated them using electricians tape.
    Fitted it all together and one of the ******s came loose when i inserted it into the headlining. Next time i fixed the wire in place so it could'nt move on top of the light.......works a treat......
    S.Lanarkshire
    Cheers i suppose i'd better look out my soldering iron.
  1. rear interior light no loom
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 18:44
  2. rear interior light- no loom !!
    By n8sby in forum Styling
    Last Post: 17th May 2010, 16:02
  3. Rear Interior Light - Loom Info
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2007, 16:48
https:www.vectra-c.comforumshowthread.php23109-Interior-light-upgrade-without-the-loom
