13th September 2017, 16:23
#11
Originally Posted by
RBH
I'm sure Gary changed the gearbox and added a few other things....only downside was he was returning about 7mpg hahaha hahaha
lol.....I used to the tuning thing - with crossflows - but parts were cheap - and none of that ECU nonsense to deal with....telling the engine what to do......that and a vivid imagination about the result....
We did have a 1600 X-Flow with 186BHP - but cost >£5k in parts and got single figure mileage - and was basically undriveable.......
I also used to believe tuning an N/A car was worthwhile....not now - unless it has the turbo thingy - too much ££££ for too little difference.....
....easier to empty the boot and the glove box of all the crap in there and get more power that way (weigh?).....
HAVING SAID ALL THAT - do like hearing about people doing the tuning thing.........so interested to hear this one.........
13th September 2017, 16:49
#12
bigwul
As said, I have changed the gearbox for a 3.94 close ratio instead of the 4.19 wide ratio for better 0-60 and it also stays in the vvt range when changing up. It has a Eds remap on and is currently at 157bhp and 190nm. I have a decat manifold to go on along with a Dbilas flowmaster intake and filter that I got second hand from Ebay. Once that is all on it should be around 170bhp but I need to change the oil cooler before fitting the manifold as it’s warped and is guaranteed to leak. Downside so far is that it returns a max of 31mpg on the motorway with 22mpg around town and down to 8mpg when I give it a thrashing. Total cost just on remap and engine parts so far is around 1.5k so not cheap. They do a turbo kit for 4K and race tune cams for 3k which I won’t be buying.
Check
HERE for upcoming meets/events
RBH liked this post
13th September 2017, 17:18
#13
Sounds like that remap alone gets good results, but hasn't it got a different exhaust ATM Gary?
Ok so it will get smoked by a mapped cdti and vxr and 2.0t, but from what I saw early this year it's didn't half take off well and once I'd realised took full throttle and some time to get going before I caught up and overtook at high speed
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
RBH liked this post
13th September 2017, 17:22
#14
Its pointless trying to improve the 1.8 unless you have bottomless pockets, just accept its the most reliable engine in the range and capable of MPG close to the Diesel's. Definitely change the box for a WR one, you'll be down to a less noisy 2500 in 70 in 5th. @simon has(or did) the most powerful 1.8 on the forum iirc.
Edi: its not Simon, cant remember the guys name.
13th September 2017, 20:29
#15
So i take it theres not much point in trying?
How much of a job would it be to convert it to a turbo or how big of a job to drop a 2.0l engine into it?
13th September 2017, 20:37
#16
VectraLife
Again..... you'd be better selling your 1.8 and buying a bigger engine car
13th September 2017, 21:02
#17
Well, ive only just bought it and was cheap at £470... buying another car is not an option right now. And this one is in immaculate condition inside and out. Just looking for some hints tips and tricks to get some more out of it.
13th September 2017, 21:21
#18
Theres a guy on the facebook page that says hes done 3 2.0T's into the 1.8. No idea of costs, but then you need to uprate the brakes and suspension, so easier just buying 2.0T from the start.
13th September 2017, 22:13
#19
If you had bought say a 1.9 cdti Z19DTH there are many cheap tricks to get stupid amounts from it easily such as a forum mapper, same now with any version of the 2.8t (teapot research inc).
I have to join the queue and say there is no cheap and easy way to tune that engine, yes Gary's goes like stink as ive had to wring the neck of mine to catch the damn thing up. But that car is more than just a mapped motor which im afraid your car would be lacking in all the other areas to be safe with more power.
I would keep the close ratio box for best performance, remember your little half an engine doesn't have bags of HP or NM
If its your hobby to mess with it, save up and buy other bits as the come like bigger brakes and better suspension and alloys. Then save and dump loads of the engine, if not save your cash and get a more tunable engine which normally come with most of the things needed to perform around it.
14th September 2017, 08:30
#20
