Likes Likes:  2
Thread: Re. 1.8 VVT engine temp guage??
    New Member bullyboy112's Avatar
    Aug 2017
    GB
    Vehicle : VAUXHALL vectra
    Trim : 1.8 design
    Engine : c18xer
    Default Re. 1.8 VVT engine temp guage??
    Hi Guys,
    Ever since recently purchasing my vectra 1.8vvt 2006, I have noticed the engine temperature guage takes ages to start moving off cold, then gets to 85 then drops back down again to zero even after 20 miles. If I go up a steep hill, it seems to start registering again, or if I restart the car it works properly? When it works, in seems to stay around 90, is this the right temperature?
    Appreciate your thoughts???
    Many thanks
    Sent from my D6603 using Tapatalk
    DONCASTER
    Vehicle : 1.8
    Trim : Sri
    Engine : 1.8, 1.8vvt,
    Mines bang on 90 after a few minutes and stays there constantly. I had symptoms like yours and changed the thermostat. Simple diy fix and common problem.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    WooHoo, its not even September and the faulty Thermostat threads have started, lol.
  4. Likes RBH liked this post
  5. #4
    Aug 2017
    GB
    Trim : 1.8 design
    Engine : c18xer
    Quote Originally Posted by john is200sport View Post
    Hi thanks for the reply. Is the thermostat different to a engine temperature sensor, or is that the same??!!
  6. #5
    Aug 2017
    GB
    Trim : 1.8 design
    Engine : c18xer
    Quote Originally Posted by Das View Post
    You always get one! Lol
  7. Likes Das liked this post
  8. #6
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    192 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Oh Lordy
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  9. #7
    DONCASTER
    Vehicle : 1.8
    Trim : Sri
  10. #8
    Oct 2014
    Normal operating temperature in these engines is 95-105°
    If it takes to long to warm up than it is a thermostat fault.
    Replace it and you should be fine.
    Sent from my SM-N920F using Tapatalk
  11. #9
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Quote Originally Posted by bullyboy112 View Post
    It will probably a good idea to change the complete plastic housing at the same time, they go brittle - the sensor at the rear, near the heater hoses - is the main cpu coolant temp sensor, they can play up too - only about £12 on ebay. & get genuine parts, not euro car part rubbish.
    Replace these 3 items + any dodgy hoses & that is most of the cooling dept dealt with - the header tank can split or crack & it's internal level sensor can go faulty, but this is more rare than the Stat problems.
    Mind you don't lose the spring clips!
    Yes, soon be autumn.
  1. Temp guage reading ???
    By azzad in forum Engine & Drivetrain
    Last Post: 6th March 2015, 19:49
  2. Temp Guage Still all over the place >
    By TILTNTURN in forum Vectra C / Signum Troubleshooting
    Last Post: 11th August 2014, 08:38
  3. 2.0 dti temp guage
    By stj in forum Engine & Drivetrain
    Last Post: 26th November 2013, 11:47
  4. temp guage ???
    By mauricemersey in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 13:13
  5. temp guage problem
    By sri-case in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 21:17
