Thread: Cd70 Radio
    Regular Member butcher-boy's Avatar
    Lincoln
    confused Cd70 Radio
    Hi all.I'm new to this please bear with me. I have a cd70 i seem to have problems getting a good fm signal, its always poor. I have ipod connected to it though the fm signal, radio is even worse now any one else have this problem, is there any thing i can do to get a better signal i like using the radio HELP PLEASE.thanks David
    Also i have a mobile phone conneted to it came with car.
    Regular Member Karl's Avatar
    Sunderland
    sounds like your aerial is goosed tbh, I know I had a warranty replacement a few years back on mine as I couldn't get any stations without crackle.
    Doesn't the CD70 have a DAB aerial though?
    Lincoln
    Thanks for reply what does the DAB aerial look like?
    Sunderland
    it has a fatter base to it from what I can remember.
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Why would it have a DAB aeriel if it's not a DAB radio ?
    Sunderland
    I wasn't sure if the CD70 was DAB or not.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    I had a similar thing, crappy reception and absolutly nothing on AM, but mine was a CDC40DAB unit. The CD70 is not DAB. Took mine in the dealer and they fitted a new aerial base unit and hey presto it worked like new, so if it's still under warranty I'd get it booked in. The aerials have a power booster , it may be that the element within the aerial base has gone, is the sat nav still working ok or are losing the signal with that too? As you are running a modulator I am assumming that the FM-Mod is dire too but not sure from your post, then it may be the HU that needs replacing, again speak to the dealer or unless someone here has had the same problem.
    Lincoln
    Hi thanks for reply sat nav works fine. Ipod adapter is a dension brought from vauxhall and fitted by vauxhall ( what they recomended ).Car is still under warranty i' ll take to them see what they say.
    Mar 2007
    I fitted a Dension FM modulator to my CD70 Nav and the FM reception went down hill big time. The lead suplied by dension that converts from the plug on the output of the I-pod FM modulator to the fakra connection is rubbish. I have tried numerous other suppliers eg auto leads but no one makes a lead with the required connections that is any better. One specialist I contacted also said they have had the same problem with the Dension.
    My FM signal for the radio is just OK when the ignition is on and therefore powering up the modulator. If it is not powered up no reception on the radio. It might be worth checking if there is a ignition live to the FM modulator. There is no ignition live to the CD 70 as standard. The easiest place to pick it up is from the cig lighter.
    Feb 2006
    Dorset
    the cd 30-40-70 put 12v up the centre core of the ariel to power the amplifier , if its not getting the signal it will be cack.
  1. Cd70 sat nav with parrot or All in one radio???
    By elite150 in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2012, 08:30
  2. CD70 Sat Nav use without Radio
    By rustle in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 01:52
  3. CD70 sat nav to aftermarket radio???
    Last Post: 6th April 2011, 19:30
  4. No AM Radio reception on CD70
    By DurhamRed in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 22:07
  5. CD70 Radio code
    By bgm46 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2008, 02:14
