Thanks Thanks:  2
Likes Likes:  5
Results 1 to 10 of 27
Thread: Air Con Question
    Jun 2014
    Engine : 1.8
    Default Air Con Question
    My air con stopped working last July I took to a guy I trust and we could see the dye was all over the condenser radiator.
    As the car then developed a leak from the coolant radiator I have had both radiators replaced with a view to getting the car regassed and restoring the air con.
    Its been regassed today there were no leaks sadly theres no air con either. The dashboard light comes on but I'm told the clutch pulley on the compressor is not engaging and being driven by the aux belt and pulley.
    The guy told me they seize up.
    However I can manually turn the clutch pulley and it rotates smoothly and freely.
    My question is when he says its seized does he mean that it cant pop in as opposed to rotate.
    Ive seen YouTube videos where you can "bridge" the relay so the clutch has to pop in and air con would start running has anyway done this? Ive read there is a sensor(s) that stop the system running if gas pressure is low but its just been regassed.
    Any ideas suggestions will be gratefully received,
    Regular Member ajcollins2's Avatar
    Jul 2014
    Ashford Middlesex
    8 Post(s)
    Vehicle : Vectra VXR & Vectra C 1.9 SRi
    Trim : VXR & SRi
    Engine : Z28NET & Y19DTH
    Mileage : 53000 & 1
    As a thought, there is a pressure switch on the system, this , iirc, controls the compressor clutch and helps with diagnostics, if you have access to tech 2 (or other diagnostics doh dah thou shalt not mention) this will give an actual pressure reading, if it's not sensing the correct pressure, the clutch will not engage, saving the compressor from running dry
  3. Likes MarkRorrison liked this post
  4. #3
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    192 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I would read through the troubleshooting section as there might be something there as it should be full of faults including ones for AC.
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  5. #4
    Jun 2014
    Engine : 1.8
    Quote Originally Posted by Dog_Book View Post
    Thanks Dogbook - been through it before I posted. @ajcollins2 ive read this too but don't know anyone near me with Tech 2 - if a high pressure or low pressure doo dah was stopping the clutch engage would there be 14vdc at the compressor connector when you turn the AC on - surely it would be 0vdc ??
  6. #5
    Jun 2014
    Engine : 1.8
    Anyone?
  7. #6
    Jul 2014
    Ashford Middlesex
    8 Post(s)
    Trim : VXR & SRi
    Mileage : 53000 & 1
    Quote Originally Posted by MarkRorrison View Post
    You could try removing the plug from the a/c pressure switch and see if the voltage drops?
  8. #7
    Jun 2014
    Engine : 1.8
    @ajcollins2 - that's an idea but I have the 14 vdc on the connector to the compressor so I don't think a low pressure/high pressure sensor is inhibiting the compressors operation I think as the air con has been off or a year since the condenser leaked the electro magnet part of the compressor has seized. Anyone know here I can buy a recon compressor, cheapest new on TheBay is £225 quid
  9. #8
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    182 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Take a drive to Birkenhead and see @Critch for some REAL diagnosis work with the Vx kit
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  10. Thanks Critch thanked for this post
    Likes Critch liked this post
  11. #9
    Jun 2014
    Engine : 1.8
    Thank you Woody - I think I might if he wants to help - I want my air con working but I don't want to waste money - hope your well buddy
    Quote Originally Posted by Woody View Post
  12. #10
    May 2012
    182 Post(s)
    Mileage : 131,000
    I'm good mate thanks
    Send @Critch a PM and see if he can fit you in soon. As his "motto" is "Test Don't Guess" , he will probably be able to tell you what "isn't wrong" BEFORE you go and "waste" your hard earned on un-necessary parts
    He got my A/C going again after a retrofit of something else went slightly amiss, simply by testing / diagnosis (I say "simply" BUT that's how he makes it look LOL)
    Hope you get it sorted without needless expense mate, and also hope that all is well with you
    Good luck
  1. HID question
    By bigjack in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2015, 18:16
  2. Air bag question
    By Slowreal in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2012, 00:43
  3. hid question
    By DAVIDD88 in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 02:20
  4. ECU Question
    By manimal in forum Engine & Drivetrain
    Last Post: 19th October 2010, 19:23
  5. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
