Thread: Steering whining!
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    StatsVehicle Info
    Default Steering whining!
    Not sure where to put this thread.. but... i was out in the car earlier and noticed some kind of whining noise when steering. Anyone ever experienced this? Sounds like it's coming from the steering wheel, not sure if something is rubbing or not.
    Regular Member rushy's Avatar
    StatsVehicle Info
    I get it from power steering pump on full lock. This is my second pump and it has done it from new, I don't think it anything to worry about.
    Jul 2006
    Mexico
    StatsVehicle Info
    You might check the oil level on that...just to make shure.
    Admin plasma's Avatar
    On the Forum
    145 Post(s)
    StatsVehicle Info
    145 Post(s)
    erm, think most of em are electric pumps.
    Jul 2006
    Mexico
    StatsVehicle Info
    Ups! forget my stupid comment above
    StatsVehicle Info
    not quite so.. you are both right..yes it is an electric pump..BUT.. it still relies on fluid ( oil) to work the steering.. so a low level would make the pump cavatate and whine..
    some pumps are noisier than others thou.. even if they are okay....
    Jul 2006
    Mexico
    StatsVehicle Info
    Thumbs up
    Sweet...you made my day again GSI
    Peterborough
    StatsVehicle Info
    Hi everyone,
    your posts are quite old so I wonder what your experiences are now with the whine from steering pump? Has it led to any other fault?
    My Vectra's steering pump has developed the whine about 10 miles after I bought it (had done 60k miles). I am arguing a case for changing it but they just keep playing with the fluid level, putting in a conditioning fluid, etc... Not with much success.
    And by the way, unlike for others, mine whine pretty much all the time, the whine pitch changes when turning the wheel and goes away only when the wheel is turned to its extremes.
    Anybody got any more ideas? Do you reckon there is a differnet primary cause?
    Cheers,
    Martin.
    StatsVehicle Info
    Mine whines mate and has done since I got a new one under warranty. You have now reported the problem to VX, so if the worst does happen you have something to back you up if you run out of warranty.
  1. whining from power steering pump
    By Siggy08 in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2011, 15:01
  2. Whining after new alternator
    By Rickiw in forum Engine & Drivetrain
    Last Post: 17th February 2011, 22:24
  3. whining egr
    By donut in forum Troubleshooting
    Last Post: 14th January 2011, 11:56
  4. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  5. Whining Brakes.
    By Russ3.2GSI in forum Engine & Drivetrain
    Last Post: 10th April 2006, 08:55
