Thread: Cv Joint
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Default Cv Joint
    Hi all ,have got a knackered drivers side CV joint can anyone tell me if they are the same in all engine sizes ,idea of price and how easy to fit.
    right, they are NOT all the same, and you will need part number 93188212 if you've got a manual gearbox..it's diffferent again if you've got an auto..
    No idea on price without making a call on monday....
    to change..remove roadwheel and undo the main driveshaft nut..now either remove the lower hub balljoint, or the damper's clamp bolts..you want to get enough room to get the driveshaft out of the outer bearing..
    now, you can either change it on the car, but i prefer to snap the driveshaft out of the box and change the CV with the shaft in a bench vice..but if you remove the shaft, block the hole to stop the fluid leaking out..
    the part number is for a kit with new clamp rings and new gaiter.. so change the lot.... remove the boot clamps, cut the gaiter off and release the circlip to remove the joint..then wipe the shaft off, slip the new gaiter up the shaft, clip on the new CV and charge it with grease..install the gaiter to the CV and pinch the clips up.. re-install the shaft into the car, and re tighten the driveshaft bearings nut..
    ayrshire scotland
    Cheers Mark thats great info will phone dealer tomorrow,by the way my car is quite noisy when driving,you can also feel a slight vibration and when going round left hand bends you can hear a sort of clicking noise from o/s/f .Do you think this is the cause.
    yep, sounds like the culprit to me..
    ayrshire scotland
    Phoned dealer today and priced CV joint kit and near fainted £160,so after a wee spell on net I found thishttp://www.buypartsby.co.uk/cv-joint...?recordID=1371 anybody heard of or used before the kit costs £38 delivered
    nope, never heard of them, but at that price if it fails then i'd not be too worried...they have to be SOME good as the sale of goods act means they have to be of merchantable quality....I'd try one..
    ayrshire scotland
    My thoughts exactly can only try it ,should be here friday
  1. cv joint
    By beat275 in forum Engine & Drivetrain
    Last Post: 1st February 2013, 15:27
  2. CV joint gone
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2012, 20:14
  3. CV joint
    By morri76 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th July 2011, 21:08
  4. C.V. Joint?
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 21:25
  5. cv joint
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2011, 17:08
