Thread: CD70 Pinouts
    Regular Member Ashtoroth's Avatar
    Default CD70 Pinouts
    Hiya.
    I had problems when connecting my carkit to my CD70, thanx to this site i found the info, I have labled a pinout with all the info i found. ( I have not tried the sub outputs, but im told they need enabling with Tech2, has anyone tried them?)
    Sorry for puting the same thread in 2 sections did not know which was best
    Ashtoroth
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Thumbs up
    connected my sub to the two pins(cd40 opera)and it works fine Able to adjust vol from stereo
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Quote Originally Posted by fenderguitar View Post
    Did you have the subwoofer volume level option showing in the menu's beforehand or did you have it Tech2'd?
    it did not show until I connected sub.it was there but not highlighted.I did not need tech 2
    Jun 2006
    Somewhere...
    Interesting that your's sensed the subwoofer, I believe that DenisTheMenace had to get his Tech2'd to enable the subout.
    Touch wood it worked OK for me.Straight plug in,I'm using a powered sub so have to keep vol about -6,makes hell of a difference
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    How are you connecting the sub up to the stereo. I'm still trying to figure it out. are you connecting an amp to a line driver connected to the rear speakers then the volume seperatly or is there another way????
    I'm connnecting mine from the back of the stereo(cd40 opera) straight to the amp thats built into sub
    Feb 2006
    Dorset
    I had mine enabled before i fitted it so wasnt sure if it would work when connected , dont think the cd70 has subwoofer output only the cdc 40 opera has it . the signal from the hu is very dirty idealy you need to clean it up a bit before the sub to get a decent sound from it ,
    I adjusted the trims on my sub Frequiences and cutoff etc and quite happy with the sound.
  1. Signum ECU Wiring/Pinouts
    By kildrum in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 14:00
  2. Pinouts needed
    By jimmyfloyd in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 18:49
  3. pinouts
    By oldcommando in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2009, 10:02
  4. Dab wiring and quadlock pinouts
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2009, 15:32
  5. CD70 Pinouts, what size terminal crimps
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2008, 09:44
cd70 pinout
cd 70 opel pinout
