Thanks Thanks:  4
Likes Likes:  2
Thread: Vectra C metal coolant pipe bleed screw
    New Member José Ręgo's Avatar
    Jul 2010
    Lisbon
    Default Vectra C metal coolant pipe bleed screw
    About a month ago I find that there was a leak of cooling fluid by the bleed screw of my Z19DHT.
    Tried to buy a new bleed screw at GM/Opel, but in Portugal they only sell the complete pipe for € 265.00.
    From what I read in the forum, it's the same in the UK.
    After searching the internet, I discovered that the VW / Audi dealers sell the same bleed screw for € 5.30.
    For those who are interested the VW/Audi bleed screw part number is the following WHT-000-316.
    Hope it helps
  2. Thanks plasma, alcutler, ajcollins2, nikolat thanked for this post
    Likes nikolat, autov liked this post
  3. #2
    Engine : 1.9 CDTi
    Thanks for the info
  4. #3
    Aug 2011
    Portugal
    Hi guys.
    A M10x15 screw with a cut made by a grinder, with a little bit of teflon, is on mine vectra.
  5. #4
    Mar 2017
    Northern Ireland
    Trim : SRi XP
    Engine : CDTi 150
    Quote Originally Posted by José Ręgo View Post
    Hope it helps
    thanks - just noticed mine is weeping too.
  6. #5
    Sep 2014
    uk
    Vehicle : vectra C sri estate auto+ hatchback auto x 2
    Trim : est sri auto hatch design auto x 2
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    The best way of slackening the bleed screw is to use a 15mm bihex ring spanner as it will fit the screw perfectly. Using a slotted screwdriver inverably ends up by breaking the slot in the bleed screw.Like xpeixeiro says you can use a M10 x 1.5mm pitch set screw and some teflon plumbers tape if you haven't a spare.
  1. For Sale: Coolant bleed screw, genuine for front coolant pipe most engines
    By Dog_Book in forum Parts for sale
    Last Post: 20th April 2017, 19:01
  2. What is this pipe called? As loosing coolant from the screw
    By Mrphil in forum Engine & Drivetrain
    Last Post: 3rd November 2015, 23:24
  3. Cdti metal coolant pipe leak
    By Dog_Book in forum Engine & Drivetrain
    Last Post: 7th August 2014, 14:08
  4. Metal Coolant Pipe
    By irmscherTI in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2013, 11:40
  5. coolant bleed screw
    By Allan-DTI in forum Engine & Drivetrain
    Last Post: 13th December 2012, 19:28
