Thread: Fitted Parrot CK3100
    Lancashire
    Default Fitted Parrot CK3100
    Yesterday I fitted a Parrot CK3100 kit to my Signum with CD70 Navi.
    I know loads of peeps have done this, so I won't bore you too much with the details
    Basically I just fitted a piece of multi-core cable into the quad-lock connector on the CD70 (for the line +, line -, mute, 12v and ground) and dropped this down to the space behind the "trinket tray" under the climate controls. There's a surprising amount of space behind it.
    I took a feed off the ciggy lighter socket up to the same spot for ignition switched power.
    I bundled-up the Parrot unit and all the excess cable harness into this space. The exception was the "Mute cable" which is bundled with its wires in the space to the right of the glovebox. The mute wire from this cable is threaded through to the main unit too. I then connected my multi-core cable to the relevant Parrot harness cables.
    I fitted the display and mic using a combination of the bits they give you with a wire clip between the r/h heated seat switch and the dash trim strip. The cables go in between the strip and the CD70 then down the front between the CD70 and the switches to the top of the climate controls. Careful routing over the top of the climate controls allow them to drop down the back to the main unit.
    All works and I'm pretty please with the result;
    Regular Member chris chennellls's Avatar
    Jun 2007
    Farnborough hants
    Hey there did you use the SOT-122 lead for the parrot ??
    Lancashire
    No, I didn't bother with it. Firstly it costs a few quid, and second I read that it was difficult to get all that cable in place behind the HU.
    I just bared some cable and poked it into the back of the car loom plug, then secured with small tie-wraps.
    Not sophisticated but it works.
    Cheers,
    Marty.
    Jun 2007
    Farnborough hants
    Ok cheers buddy, ill have a word with the bloke i know who works for surrey car radio see what he has to say, after all dont really fancy hacking away at some of the orignal wiring for the sake of £20 and a few cuts Cheers mate
  1. Parrot ck3100
    By 1973andi in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2010, 18:47
  2. Parrot CK3100
    By graham22vti in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 19:31
  3. Parrot ck3100
    By nick-v2.2 in forum General items for sale
    Last Post: 16th April 2009, 13:20
  4. parrot ck3100
    By bigmac in forum Parts for sale
    Last Post: 17th January 2009, 23:56
  5. Parrot CK3100
    By GARY3306 in forum Parts for sale
    Last Post: 1st August 2007, 23:18
