Results 1 to 10 of 19
Thread: Fault F displayed on Radio LCD
    Apr 2014
    ireland
    Vehicle : vectra sri 150
    Trim : sri
    Engine : 150
    Default Fault F displayed on Radio LCD
    Hi..
    Need help. My 08 Vectra 150 bhp 1.9 sri stopped dead on the side of the road with warning lights emitted. Tried to start but kept turning over. Managed to push the car off the road and now its not turning over at all. I've noticed F displayed on the radio LCD and when I've the key turned to on the engine management light doesn't come on at all( usually flashes briefly)
    Also have noticed that my gauges aren't working either fuel and engine temp.
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    the f displayed i think is the outside temp sensorand the rest could be faulty cim try the conector on your abs unit another thing u could try is disconect your battery for about 30 mins
    Apr 2014
    ireland
    Trim : sri
    Engine : 150
    HI Outside temp gauge is working correctly, The F fault is displayed beside the mileage and MPG on the LCD screen. Ill post a pick up later of the fault.
    Apr 2014
    ireland
    Trim : sri
    Engine : 150
    Tried the OBD2 scanner and not its unable to read any codes now its unable to connect to the car. Looks like no power getting to the ecru. All fuses are Okay
    Regular Member pattz123's Avatar
    Motherwell
    17 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    F is for Flat battery hence why theres not enough power going to ur ecu's to get fault codes, as for the engine cutting out possibly timing belt gone, alternator or may be loose battery connection. Hope u get it back running soon.
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Lol that's a good one.! Not heard of that before. It has lost comms with the engine ecu which is why it displays F and also explains why it's not cranking over and also why you cannot communicate via obd. Do check your battery voltage is good then check things like abs plug and power steering plug as the high speed canbus runs through it
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Also does the fuel gauge read or remain at zero?
    Apr 2014
    ireland
    Trim : sri
    Engine : 150
    Okay put jump leads on and still got F fault on the LCD. Checked relay 7 and it's working.
    All instruments are still dead. Can't find the location of the ECU any ideas??
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Year : 56
    behind the front bumper just below the headlight on the driver side
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Year : 56
    have u looked in the how tos under general eletrics instruments failure checks
  1. Safeguard Displayed on radio
    By tommyd in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2014, 09:41
  2. Radio fault
    By jamiedvvt in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 16:43
  3. AM Radio Fault
    By exclusive07 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2010, 12:56
  4. CDR2005 Radio / Panel Display Fault
    By born to be in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2010, 01:19
  5. aftermarket radio - fault light on
    By the-ferret in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 19:52
