Thread: Paint problem I think
    cambridgeshire
    Default Paint problem I think
    Ladies and Gentlemen, I have a quick question, I cleaned the Bird guano from the bonnet of the car the other day, to find a great patch (6cm X 6cm) of what I can only describe as lacquer peeled from the car exposing the base paint underneath.
    I was not using anything other than car shampoo to clean it, honest not a Brillo pad in site.
    Do you think this is a fault with the paint? how long is the paint warranty on a Vauxhall (53 Signum) Is it worth visiting the dealer to see if it is covered under warranty. Bit of a pain as you will aggree.
    Ian B.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    crikey Ian what you feeeding your birds on round your way?
    Regular Member Deadman's Avatar
    earth
    How long had the bird s*it been on there? It happened to my old Primera too.
    cambridgeshire
    I tell you soul man I don't feed them at all, I guess the guano had been there about 36 hours, not sure been too busy bad week last week.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Took the paint off down to the primer on the roof of my old Puma last year
    the problem is the acid in the bird poo...it eats the laquer right off..you'll have to get it repainted....
    if you ever get any on your car, wash it straight off....
    cambridgeshire
    Ah well guees I will be getting the Bonnet re-sprayed then, anyone know any good body shops in the Peterborough area?
    Ian B.
    dudley
    Default Paint Problem I Think
    Bird pooh is best removed by rehydrating it with a really damp sponge. Leave it on for a good ten minutes and the pooh will slide off.
    Paint should be better than that, see a dealer first.
    Chris
    LOL, I doubt seriously a dealer will even entertain the idea that they should repair the damaged panel..Bird poo is very acidic and attacks the laquer.. it's a well known thing, and totally outside the control of VX or it's agents in it's application..
    It's 'just one of those things'..folks accept it..
    dudley
    The laquar is there to protect the paint against bird dropping etc. I spent 16 years in paint and coatings development and peeling should not occur within the time frame your car falls into. The surface would have to be damaged by abrasion or it's been poorly applied. Has it been repaired in it's lifetime?
    It would part of the barrage of tests, paints have to endure.
    You should of course remove bird dropping as soon as, especially in strong sunlight.
    Chris
  1. Replies: 2
    Last Post: 17th November 2012, 11:24
  2. Paint problem need help
    By Ralphwells1967 in forum Detailing and Car Care Discussion
    Last Post: 9th May 2012, 06:56
  3. Paint problem (VXR rear skirt)...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 22:13
  4. normal spray paint or caliper paint?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 20:59
  5. Paint problem
    Last Post: 10th July 2007, 09:43
