Results 1 to 10 of 13
Thread: How to change the oil on a dti
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default How to change the oil on a dti
    I know it seems stupid but how do you?
    [Ex]Admin Duncan's Avatar
    You've seen my How 2 which relates to a 2.0T? Is it not the same for a DTi? - just with different locations for the filter and maybe the sump plug.
    Jul 2006
    Northampton
    Trim : Sri
    OK thanks
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    On my old Vec B (2.0 DTi) the filter was an element type in a black plastic enclosure and not a spin on type.
    yep..the filter is located under the top cover of the engine.. look for a black plastic cap..
    if you can wait till later this week i'll show you what you're looking for if you fancy a meet in MK?
    Feb 2006
    Guttedsville
    MK donalds?
    Nicking Ya Dinner.
    Drop the engine sheild, but support it as you do or it drops and rips.
    Sump plug is to the rear right of the sump, torx drive required
    Filter is at the front right, black housing just under the cover with 32mm nut fitting on top
    So it's filler cap off, drain oil, change filter while oil is draining, remember to renew the rubber bands on the stalk inside of the filter housing, fit new filter, fit new sump ring, refit sump plug, fill with oil, 4.5 litres iirc, could be 5, and put cap back on, fire it up and leave to idle for a minute, turn off leave ten minutes, check level.
    If you want to flush as well, just add to a warm engine and idle for up to ten mins, do not drive or rev car at this time, after you have done the oil change, add oil reconditioner to the new oil to ensure any flush left behind wont cause you grief.
    hth
    Jul 2006
    Northampton
    Trim : Sri
    Thanks alot guys that really helps, it will have to wait until the weekend now tho... An MK meet sounds good but it will have to wait for my alloys to be fitted as i recently (while thinking about changing the oil) found that my tyre was bald so im on the skinny wheel for the mo. Get new wheels at weekend and adaptors following weekend!
    EDIT: Got these 18"
    Jul 2006
    Northampton
    Trim : Sri
    If you want a MK meet, we can at the MK hockey Stadium with the MK chavs at the MK Krooze! or do something else? If you want any help organising i can
    erm.. how about a chav free zone.. either that, or there is another 'workshop' meet this weekend on sunday?..come and meet some of the gang..
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
