Results 1 to 10 of 13
Thread: Pollen Filter location?
    Default Pollen Filter location?
    Ok, i might be a bit thick here but where the **** is the pollen filter? Had a quick look and couldnt see it...was in lazy ar*e mode so didnt want to undo any clips, nuts etc...First person to let me know gets a kit-kat
    Regular Member Basil's Avatar
    Nottingham
    Scooby, you could try the top end of the engine bay (towards the windscreen) there should be a flat-ish plastic casing about 2 foot across, should be in there mate.
    If i'm wrong on the location then it's because I cannot be ar$$ed to go out to my car and look for myself, but thats where they usually are, if in doubt look for the flat-ish casing as mentioned earlier.
    Hope it helps
    Quote Originally Posted by Basil
    I reckon thats a quote from a mechanics handbook at a Vauxhall dealer lol... but anyways...i'll have a squizz tomorrow in the daylight Cheers
    Pretty much as Basil said.
    Pop your bonnet and look at the plastic 'ledge' that is towards the windscreen (running across the width of the car). Go to the bit that is between the N/S suspension mount and the coolant tank and look past the spongy bit of 'beading'. You'll see a fairly large cover flap (fairly well disguised) that you need to pop up and inside you'll see the pollen filter. A couple of white clips either side at the top will release it.
    I hope I've described that well enough for you to find it!!
    Cheers Duncan...i'll whip it off tomorrow
    Nottingham
    Quote Originally Posted by Scooby
    ooo errr
    In a house
    Default Vauxhall Vectra water leak in passenger footwell
    I have just fixed my Vectra (2003). As described by Duncan - thanks.
    Additional comments: The hiden section beneath the passenger window wiper - on the plastic ledge that runs accross the windscreen. You can just about see that there is a split in the plastic that can be pulled up.
    The white pollen filter can stay where it is, just in front of it is a hole (which will be covered in water and dirt) - just put you hand in and push the dirt through. A small bit of pressure will release it all.
    My pollen filter was absolutely soaked so i asume this will probably need replacing. I will see how it dries out first!
    This is definitely not a job for the garage - they will charge you lots of money £££.
    Good luck
    Another 'victim' of the bunged up drain hole! Hope it didn't get as far as soaking your passenger side footwell carpet?
    For the cost of a new filter, about a tenner(ish) for the (better) active charcoal one, I'd replace it TBH.
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    Quote Originally Posted by Gee-meister View Post
    Do Halfords do pollen filters or is this a trip to VX?
    11 Post(s)
    Vauxhalls price for a pollen filter is approx the same price as elsewhere, as are many of their service parts.
    Somewhere around £10 to £12.
  1. Pollen Filter
    By MattW in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2009, 01:26
  2. Pollen Filter
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 21st July 2008, 22:37
  3. Pollen filter
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2007, 20:34
  4. Pollen filter
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2007, 14:11
  5. Pollen Filter.....
    By nabs44 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2006, 08:51
vauxhall vectra c pollen filter location
2005 vectra pollen filter
