19th April 2017, 19:46
#1
2.2 Direct Juddering / Engine light comes on at 30mph+
Hi Guys,
My 2.2 Direct has lately developed an issue, Yesterday it went into limp mode with the Car/Spanner icon showing on dash but I restarted and it was fine
Now today I've been using it fine until this evening it started juddering really bad, The car drives but judders badly and doesn't seem to want to go above 30+ when it does the engine light comes on
It's not long has a new fuel pump fitted by the previous owner and I've checked and cleaned the spark plugs and tried unplugging the MAF sensor and it made no difference
19th April 2017, 20:30
#2
Fuel regulator or coil pack matey, more like the regulator though...
Clive
19th April 2017, 21:16
#3
Originally Posted by
lizard
Clive
It's already had a new fuel regulator (not long before I bought it) Both the fuel pump and regulator got done (perhaps they had issues??) They couldnt of packed in already surely.
I've already had the coil pack off but not sure how to check that? I checked the spark plugs they seemed fine tried switching around and cleaning them etc It's really annoying as the cars been fine all day lol always the way
19th April 2017, 22:50
#4
needs the codes read really
20th April 2017, 10:42
#5
vectra ste
Guesswork was never a reliable method of fault diagnosis.
20th April 2017, 16:12
#6
I've had it plugged in and it threw up a load of codes at first, MAF and swirl flaps which they checked and some minor things they cleared the codes and then the only thing that come up after a few attempts was cylinder 1 misfire.
I've replaced the spark plugs and still the same juddering and going no more then 30mph then light comes on
20th April 2017, 22:25
#7
Mine did this and was fouling the plugs, high pressure fuel pump.
basically there are two fuel pumps, one on the side of cylinder head the other in the tank, which one did previous owner change?
20th April 2017, 22:44
#8
VectraJamie
Hi Guys,
i would buy new spark plugs to eliminate them
there cheap to buy maybe a cheap fix means its saying cylinder number 1
21st April 2017, 08:49
#9
Tiggz
The one on the head (It's from Evolution Autos still got the guarentee stickers on it) I never knew there was two is it easy to access?
21st April 2017, 08:50
#10
Thats what I was hoping but I've already replaced the spark plugs with a new set of bosch ones
Post Thanks / Like - 1 Thanks, 1 Likes
