Thanks Thanks:  2
Likes Likes:  2
Results 1 to 10 of 14
Thread: 2.2 Direct Juddering / Engine light comes on at 30mph+
    Mar 2017
    W mids
    Engine : 2.2
    Default 2.2 Direct Juddering / Engine light comes on at 30mph+
    Hi Guys,
    My 2.2 Direct has lately developed an issue, Yesterday it went into limp mode with the Car/Spanner icon showing on dash but I restarted and it was fine
    Now today I've been using it fine until this evening it started juddering really bad, The car drives but judders badly and doesn't seem to want to go above 30+ when it does the engine light comes on
    It's not long has a new fuel pump fitted by the previous owner and I've checked and cleaned the spark plugs and tried unplugging the MAF sensor and it made no difference
    Oct 2006
    southampton
    15 Post(s)
    Fuel regulator or coil pack matey, more like the regulator though...
    Clive
    Mar 2017
    W mids
    Engine : 2.2
    Quote Originally Posted by lizard View Post
    Clive
    It's already had a new fuel regulator (not long before I bought it) Both the fuel pump and regulator got done (perhaps they had issues??) They couldnt of packed in already surely.
    I've already had the coil pack off but not sure how to check that? I checked the spark plugs they seemed fine tried switching around and cleaning them etc It's really annoying as the cars been fine all day lol always the way
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    needs the codes read really
    11 Post(s)
    Quote Originally Posted by vectra ste View Post
    Guesswork was never a reliable method of fault diagnosis.
    Mar 2017
    W mids
    Engine : 2.2
    I've had it plugged in and it threw up a load of codes at first, MAF and swirl flaps which they checked and some minor things they cleared the codes and then the only thing that come up after a few attempts was cylinder 1 misfire.
    I've replaced the spark plugs and still the same juddering and going no more then 30mph then light comes on
    Jun 2014
    Tonbridge
    Engine : 2.2 direct
    Year : 07
    Mileage : 123k
    Mine did this and was fouling the plugs, high pressure fuel pump.
    basically there are two fuel pumps, one on the side of cylinder head the other in the tank, which one did previous owner change?
  8. Thanks VectraJamie thanked for this post
  9. #8
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by VectraJamie View Post
    Hi Guys,
    i would buy new spark plugs to eliminate them
    there cheap to buy maybe a cheap fix means its saying cylinder number 1
  10. #9
    Mar 2017
    W mids
    Engine : 2.2
    Quote Originally Posted by Tiggz View Post
    The one on the head (It's from Evolution Autos still got the guarentee stickers on it) I never knew there was two is it easy to access?
  11. #10
    Mar 2017
    W mids
    Engine : 2.2
    Thats what I was hoping but I've already replaced the spark plugs with a new set of bosch ones
  12. Thanks vectra ste thanked for this post
    Likes vectra ste liked this post
  1. Replies: 2
    Last Post: 5th March 2017, 12:31
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. Engine fault light on / Juddering when hot
    By Angelchops in forum Engine & Drivetrain
    Last Post: 17th September 2011, 19:16
  4. Starting - engine juddering
    By GWHIZZER in forum Engine & Drivetrain
    Last Post: 16th July 2009, 14:50
  5. 2.2 direct engine light
    By idobigmls in forum Engine & Drivetrain
    Last Post: 26th May 2009, 20:19
