Results 1 to 10 of 11
Thread: Blower Motor problem NOT WORKING!
Hybrid View
    New Member Nseries's Avatar
    Apr 2017
    Newark
    Trim : SXi
    Engine : CDTi (120)
    Mileage : 254 000
    Question Blower Motor problem NOT WORKING!
    Hey to everyone
    New Vectra owner here, so have questions about stuff.
    Main thing is that the blower motor isn't working at any speed.
    Google'd a bit and I found you can change resistor (Ebay from 3pounds) or full blower motor (Ebay from 25pounds). Does the resistor help solve the problem or do I need to change full blower?
    Thank you.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Hi , have you read up on the causes of the blower not working ??? some times it is due to water getting through where the pollen filter is and goosing the blower . Have you got wet carpet on the passenger side ? The main cause is blocked drainage holes in the scuttle tray. For the sake of £3 I would start with the resistor .
    If you scroll down this page you will threads of simular blower problems ... HTH
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    If the resistor has gone, it should still work on the highest speed setting.
    Apr 2017
    Newark
    Trim : SXi
    Engine : CDTi (120)
    Mileage : 254 000
    Its not working at any speed.
    So will try to check the cabin filter today and check if the passenger side is wet or not.
    Oxfordshire
    13 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    Take the pollen filter out and see if you can turn the motor by hand.
    Apr 2017
    Newark
    Trim : SXi
    Engine : CDTi (120)
    Mileage : 254 000
    I checked the pollen filter it is still average condition, but the hole for the water under it was clogged and there was water below the filter. I unclogged the hole and cleaned it, but maybe then it was water it spilled on the blower motor and burned it ???
    Thanks.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    Keep us updated ,cos we are a nosey bunch .lol
    Apr 2017
    Newark
    Trim : SXi
    Engine : CDTi (120)
    Mileage : 254 000
    Quote Originally Posted by soulman View Post
    I tried to spin it by hand and it didn't moved, when I did it with screwdriver the blower motor spin but I had to put a bit of pressure to push it. I think it was rusted from long time not working.
    So now I know that I will have to change it for sure
    Oxfordshire
    13 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by Nseries View Post
    Not sure if you can see the HOW2 section (some can, some can't) but there's a HOW2 for lubricating the spindle bearings. That's all it might need, instead of going to the expense of replacing it.
    Apr 2017
    Newark
    Trim : SXi
    Engine : CDTi (120)
    Mileage : 254 000
    I can't see it
    If I would I would be doing that
  1. heater blower motor problem - again
    By scottswfc in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2016, 15:50
  2. Blower motor
    By Shaddex in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2014, 11:38
  3. blower motor
    By nokiaman1978 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2014, 10:43
  4. Vectra heater blower motor problem...ongoing!
    By neo196910 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2014, 19:51
  5. Blower motor
    By Butler in forum Bodywork & Interior
    Last Post: 13th January 2009, 09:47
