Results 1 to 10 of 11
Thread: To LPG or Not to LPG? That is the question?
    Regular Member 65gilly's Avatar
    Mar 2007
    North Lincs
    Default To LPG or Not to LPG? That is the question?
    I put £100 a week (thats a minimum amount ) on petrol through my 2.2. A chap at work has a converted Range Rover and swears by LPG. He has put been persuading me that it would be worth converting my car with the costs covered in about 6 months, however, I am not sure as I have no real knowledge of LPG which is where I hope you guys will be able to help Definite positive on cost, cannot move closer to work as it will cost me more in child care than pertol! Rather keep up the travelling but reduce the amount of tax which I give tto that day light robber Brown
    Any experiences for the good or bad? It is right that there are less impurities in LPG hence the oil is cleaner when changed? Is there much loss of performance?
    Hope you can help! Any advice gratefully recieved
    Regular Member Shazzle's Avatar
    Mar 2007
    Berkshire
    Good now, but wait until Mr Brown changes his mind on the taxation!!!!
    Why don't you just buy a nice Diesel?
    the big surprise will come with trying to get insurance... what you save on fuel will be eaten up by inflated insurance premiums as the car will now be classed as modified..and you will need an engineers report on the conversion in most cases
    Regular Member j13hdb's Avatar
    Nottingham
    Apparently they run about the same. it costs about 50p a litre but where will you hide the gas cylinder? Also no Channel Tunnel. Like above get a 150bhp diesel that can be remapped and still economical or a motorbike for work? Have got a 125cc slowped that uses as much petrol all week as car uses in 1 trip! I know I aint Barry Sheene on a 125 but in 2 years using it 6 months a year it's paid the cost of buying,insuring and running it just for getting to work!Really should get a bigger bike though!!! Mind you it dries the Mrs' hair
    Regular Member The Doc's Avatar
    'Norf Yorks.
    http://www.greenfuel.org.uk/
    Good site to give you an idea what you're savings are.
    Any GOOD fitter should provide the certificate you need for insurance.
    Adrian Flux amongst most good insurers recognise it without the stupid hike....
    Nottingham
    Sorry - but that's ******. Been driving LPG for 6 years now (three diff ins companies) and makes no difference whatsover. (aprt from some cannot quote online) You will recieve a certificate when converted to confirm done to standards. Cylinder replaces spare wheel and yes, channel tunnel is a no go but ferries are more relaxing anyway!
    Saves me about £200 per month (2.8 elite nav)
    Nicking Ya Dinner.
    Quote Originally Posted by stripey View Post
    This is correct btw, every conversion has to be signed off iirc, and once done is considered no more of a risk than a normal petrol car, actually safer, if the tank splits it just vents the gas.
    Performance, you will notice a slight drop off, not enough to bother you though.
    Tank, you need to get the spare wheel one, I think it's called a toridial one
    Costs, The conversion will cost you between £1700 - £2000 for your car
    Tax, it's sub'd at the moment, but that could all change if it catches on
    Engine, it runs hotter because it's a different burn in the cylinders, and can dry the bores and burn out valve seats, this can be sorted by using a lube system which adds to the gas, better way is to run on petrol for 10% of your weekly mileage.
    Reliability, expect to have to take it back to the fitters at least once, you have a free inspection anyway after so many miles where they check everything is up to spec.
    hth
    Mar 2007
    South wales
    Wrong! Most major insurers (direct line for one) actually give a 5% discount for running LPG. Dont know why.
    I had a 4.0 Cherokee running on LPG for 4 years before the Vec. No real drawbacks except for limited fill up points, but it was still rare that I had to run on petrol.
    fair enough!!..gawd.....
    lets just leave it at , thats not been my experience folks on LPG converted landrovers....
    try to pass on experiences and get shot for it......
    Nicking Ya Dinner.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
