Results 1 to 10 of 16
Thread: Which size brake discs????
    Regular Member henocsr's Avatar
    rushden
    confused Which size brake discs????
    The front pads and discs on my 2004 Gsi need changing. I have been looking around for disc and there 2 types, one set are 302mm and the other 314mm.
    Does anyone know the vin range cut off when vauxhall changed from 302 to 314??
    Also has anone fitted EBC redstuff pads to their vectra and if so how would you rate them.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Think your 04 plate will be the 314mm disks mate.
    you will have 314's...same as me....
    EBC redstuff is a matter of taste.. Mark the Cabby loves his in his 314 setup, but plasma hated his and went on to fit police spec 314mm pads instead..
    in fact, as you're local, if you want a disc and pad kit, i'll lay you one in at trade prices..
    There are actually three sizes of front brake discs for the Vectra C :
    285mm - all models, except as below
    302mm - 2.0T
    314mm - 3.2 V6 / 3.0 CDTI V6
    Two for rear brake discs :
    278mm (solid) - all models, except as below
    292mm (vented) - 2.0T / 3.2 V6 / 3.0 CDTI V6
    erm, thats not quite right, as the early V6 3.2's where fitted with 302mm discs as well, then VX upgraded them to 314's..
    rushden
    cheers for your help guys, i didnt want to make a costly mistake and order up the wrong ones.
    i think i will go for the EBC redstuff pads this time around and if they are no good then wont bother next time, and i think i may have to get out the blue caliper paint as well, i think the silver VXRs with the blue brakes look awesome.
    i will put some pics on when finished, i need an updated one of my car with the autotint design dtm style spolier on
    302mm - 2.0T
    And don`t forget the 345mm babies on the vxr !!
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Interesting - do you know when they changed? My fronts were changed about 18 months ago as they were badly worn - new parts fitted were G0093175606.
    I know at the time the only place I could get them done was the dealers - local brake centre could not get the correct size (pads I think) for the 3.2.
    Quote Originally Posted by henocsr View Post
    http://forum.vectra-c.com/showthread.php?t=20531 - of any interest?
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Yep, 314's indicated in first 2004 Brochure, 302's (as fitted to my 2.0T) in earlier brochures. Looks like 312's from 2004 on for the 3.2 V6's.
  1. What are my Rear brake discs size?
    By signum04 in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2012, 18:07
  2. What Brembo brake pads & Discs Size 1.9?
    By Elahi_786 in forum Handling & Braking
    Last Post: 8th February 2011, 15:39
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. wHAT SIZE DISCS?????????
    By bigboynigs in forum Handling & Braking
    Last Post: 15th February 2009, 13:17
  5. what size are my brake discs???
    By dannydm1 in forum Handling & Braking
    Last Post: 27th October 2008, 21:09
