Thread: P1625 Main Relay Circuit High/Low Voltage
    May 2016
    UK
    Vehicle : Vextra
    Trim : SRI 2.0 TURBO
    Engine : 2.0 turbo
    Default P1625 Main Relay Circuit High/Low Voltage
    Vectra 2.0 turbo petrol
    Anyone know what the fault could be?
    P1625
    Main Relay Circuit High Voltage
    P1625
    Main Relay Circuit Low Voltage
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Done a search for you, this seems to pop up on the Z20NET...
    https://www.vectra-c.com/forum/showt...d-brake-lights
    May 2016
    UK
    Vehicle : Vextra
    Engine : 2.0 turbo
    Cheers for that, any further advice would help thanks.
    Full Member
    Feb 2017
    Birstall, West Yorkshire
    Vehicle : Vectra SRi CDTi 150
    Engine : 1.9 CDTi 150 Z19DTH
    Mileage : 80000
    Quote Originally Posted by jaygsi View Post
    Have you tried what the linked thread said Nicrok did?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    I had this on my 1.9 (I know its a different engine) and had the same fault codes. After changing every fuse and relay in the car I had to admit defeat and had the ECU changed ( by little teapot) and its been perfect ever since. It turned out that my ECU had been taken apart and re mapped but not resealed and the water and cold got into it and slowly destroyed it.
    I spent years researching what it could be but never found a definite answer but the "main relay" fault codes did point towards the ECU when I found what little info I could find
    May 2016
    UK
    Vehicle : Vextra
    Engine : 2.0 turbo
    I'm not sure where the abs and ecu plugs in the engine bay are?
    May 2016
    UK
    Vehicle : Vextra
    Engine : 2.0 turbo
    bttt
  1. P1482 - Fan Control 2 Circuit High Voltage
    By m2yuout in forum Y & Z30DT Specific
    Last Post: 29th February 2016, 21:59
  2. P1625-58 Main Relay Opens Too Early
    By justin32 in forum Engine & Drivetrain
    Last Post: 9th September 2015, 07:19
  3. B2966 - Driver Doorknob Circuit Open or High Voltage
    By kingarthas in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2014, 15:32
  4. P1590 - Vacuum Solenoid Valve Circuit High Voltage
    By zk001 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2013, 11:03
  5. P0615-02 Starter relay circuit voltage (fault code any help)
    By eaglepva in forum Engine & Drivetrain
    Last Post: 18th September 2011, 15:17
vauxhall fault code p1625
Vauxhall DTC P1625-C
p1625 swift main relay
Vauxhall DTC P1625-2
