Thread: Suspect Bushes
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    Default Suspect Bushes
    Just wondering if anyone can shed some light on what I'm up against.
    Whenever I reverse the car slowly, I can hear what can only be described
    as a creaking noise coming from the rear, even when I move into 1st and move slowly forward I get the same creaking noise (sometimes a little bit like a ticking clunk).
    If I open my boot and push up and down on my cars rear end I can hear the passengers side rear corner clunking, If push up and down a little harder I can hear both rear corners clunking.
    Any Ideas, it's a gsi if that helps.
    sounds like rear shocks.. are they showing signs of leaking?..Have you looked at the shocks bushes?..
    other 'favorites' for rear end noise include the anti roll bar links and bushes, and the top arm void bushes..
    Ayrshire, Scotland
    Cheers m8, without wanting to sound daft, what would be the signs for leaking.
    'wet' oil stains in the dirt on the lower portion of the dampers..they won't be wringing wet with oil, but if they look wet stained then they'll be the cause..
  1. What happens if I just unplug a suspect bad EGR on a 1.9CDTI 150?
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2012, 09:39
  2. Replies: 5
    Last Post: 21st March 2010, 12:34
  3. egr valve suspect?
    By chowwie in forum Engine & Drivetrain
    Last Post: 2nd November 2008, 15:29
  4. Looks a bit suspect?
    By RocketRuss in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 10:47
  5. Suspect Injector Problem
    By DAVO in forum Engine & Drivetrain
    Last Post: 3rd December 2007, 16:59
