Results 1 to 3 of 3
Thread: Z30dt - p1243-06 swirl level control solinoid valve low voltage
    Regular Member rudeboy_29's Avatar
    Jul 2011
    Doncaster
    Engine : Z30dt
    Year : 55
    Mileage : 132k
    Default Z30dt - p1243-06 swirl level control solinoid valve low voltage
    I had this problem a while now and it's doing my head in! I want to get it fixed/ serviced so I can go get the get/Dpd removed and remapped!
    basicly get eml light then engine management, no power and when stood still at idle it revs up to 1000rpm ....
    looked at it AGAIN tonight and as an experiment unplugged egr and new code for low voltage to egr come up, so put back and cleared code, then unplugged the lead to the swirl control solinoid (the one for the front bank next to the egr) and nothing changed so I'm thinking either that one, or the one for other bank under the turbo or both are faulty or broke...
    anyone got experiance with this? Got part numbers? Can you change just that solinoid ?
    Cheers for any help you provide
    Nov 2018
    Latvia
    Vehicle : Opel
    Trim : Signum
    Engine : 3.0 cdti
    i got this problem too. Did you fix and faind the problem?
    Apr 2008
    West Yorkshire
    The solenoid is the one that supplies vacuum to the swirl baines. The electrical connection plugs on the side of the swirl valves are the position feedback wipers.
  1. glow duration control voltage too low
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 22nd December 2012, 13:06
  2. Fault p0400 (57) (EGR Valve Voltage Low) on Z22YH
    By VeCeZ22YH in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2012, 20:25
  3. Replies: 1
    Last Post: 15th February 2012, 06:43
  4. Just a quick one! Voltage control question
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2011, 17:25
https:www.vectra-c.comforumshowthread.php228966-Z30dt-p1243-06-swirl-level-control-solinoid-valve-low-voltage
