Thread: Need Help with Crankshaft Pulley Bolt!!
    Derby
    Default Need Help with Crankshaft Pulley Bolt!!
    I need to replace the crankshaft pulley as the old one has disintegrated (only £140, what a rip!!). My questions are 1) is the bolt conventional LH thread removal, and 2) Whats the best way to keep the crankshaft still while applying the obvious extreem torque to loosen the bolt, assuming the special tool is not available?? The bolt seems incredibly stubborn! Help!!!
    to 'lock' the engine you can remove the starter motor and jam the flywheel ringgear to stop the engine turning as you undo the bolt, which to the best of my recollection is right hand thread, and just very tight..
    Derby
    Default Thanks!
    Good idea, I can remember doing that years ago now you have mentioned it. I bought a new bolt, no wonder it's tight, looks like something you would expect to see holding a jumbo engine on not a crankshaft pulley! Can't help thinking its a bit over the top.......
    Jan 2006
    Skynet HQ EMEC#5
    A bit over the top is better, you want it to do it's job don't you?
    Derby
    confused Removed at last!
    Finally got the ******* out!! Locking the flywheel by removing the Starter Motor is a great way round not using the special tool to hold the crankshaft, but removing and replacing the Starter is not the easiest job, access is difficult.I used a socket to jam the flywheel and it worked a treat. Be Warned, the Pulley wheel bolt, although conventional thread, is MEGA tight!! I resorted to some heat from a hot air gun before finally managing to realease the bolt, but it still took an awful lot of force to loosen it.
    Surely it doesn't need to be engineered like this?? What happend to the 4 or 5 smaller bolts locked with a safety washer? And £150 for the pulley and bolt is outrageous, I might as well buy a foreign car, didn't vauxhall spares used to be cheap??
    glad you've got it out....and i know that the pulley is dear, but even if you'd have had a peugeot HDi or a renault DCi, the pulleys would have been more expensive......
    lets hope it's all sorted out now..
  1. Crankshaft pulley. Vec c and b ??
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 18:43
  2. Crankshaft Pulley
    By 123ashleyp in forum Engine & Drivetrain
    Last Post: 5th March 2010, 12:37
  3. crankshaft pulley
    By djsoundman in forum Engine & Drivetrain
    Last Post: 20th November 2009, 12:05
  4. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
  5. Yet Another Crankshaft Pulley!
    Last Post: 13th January 2008, 00:27
vectra c Crankshaft pulley starter motor
